I bought a mini revo about a year ago before the mini Grave Digger came out with plans to convert it to Digger style. I eventually bought the body, bumpers and wheels and a few other things as they were available. I never made a thread because it wasn't an all out build like I normally do.
I lost interest in the truck after installing the gpm shocks. no matter what weight oil I put in it the thing it just doesn't have any dampening. I've read that the pistons in these shocks are too small for the body that they are in. I recently picked up some traxxas gtr's but haven't installed them yet.
installed now:
jconcepts rulux wheels
proline dirt hawgs with titus beadlocks
traxxas response pro wheels and tires
traxxas center diff
traxxas steel cvd's
traxxas Grave Digger Body with body posts
traxxas Grave Digger wheels and tires
traxxas Grave Digger front and rear bumper
traxxas aluminum push rods and toe rods
hot racing aluminum steering knuckles
hot racing sway bar
hot racing aluminum steering post
hot racing aluminum hex pin set
hot racing aluminum front and rear rocker arms
gpm red aluminum shocks
tbone- front rear center and wheelie bar (not necessary with center diff installed)
spc 50c 2s x2
For my birthday I received a gift certificate at the lhs so I bought all the red aluminum parts that they had. I normally wouldn't buy integy. i soldered bigger connectors on the stock motor so that it works with a castle esc. I haven't decided if I want to go big block or do a neu motor down the road. I have a 7700 and a 5700 that are candidates for installing but I'm not sure yet. I may wait to see how the vxl motor does with an upgraded esc.
parts waiting to go on:
integy red front and rear bulkheads
integy red front and rear body mounts
integy steel center shafts
traxxas gtr shocks
hitec servo
castle sv2 or mamba monster
I get home from working offshore next Wednesday so the new parts should go on then. I'm considering the integy carbon fiber chassis because i'm a cf junky. If there are any other mods that I should order before then please feel free to let me know. I may be missing some stuff since I made the lists off the top of my head. here are some pics so far.
X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
looks good!
i went with the hr shocks red pistons and tin shafts. the bottom cap snaps on the gtr shocks and hr screw on.might have problems with the cap popping off if you jump hard
gpm have their own problems same length as stock but less stroke!
Can i take the piston and shaft from the gtr and put them in a hot racing body?
Sent from my iPhone 4S using Tapatalk
Okay I figured it out. I just placed an order for another round of mods!
Integy Carbon Fiber chassis for mini revo (works with revo body)
Integy Red heatskink and fan
GPM red front and rear shock towers
Hot Racing threaded shock towers
I was really thinking of doing the 200mm touring car conversion but I decided to keep this an offroader.
Yes. Hot racing shock bodies take traxxas internal parts
Careful with too much aluminum looks nice but the weight adds up!and aluminum bends and stays bent
looks great.
Awesome build so far! Can't wait to see the result.
thanks dude! I'm look forward to installing the cf chassis, hopefully it'll be in by next weekend.
The order has shipped! I'm looking to replace the titus beadlocks with something a little lighter. what wheels provided the largest offset for the dirt hawgs?
Anyone?
Desperados are pretty wide, but hpi super star wheels have a little more offset I think. Personally I think the dirthawg tires are not wide enough for hpi wheels and thats why I went with desperados.
Thanks. It's going to be those or Traxxas white dish that I go with for them.
I made it home and started messing with the merv. I don't want to tear it down till I get the chassis but I guess I'll put the diffs together tomorrow.
I'm going to pull the red lights out of the 1/10th Digger and put them on this body.
I really don't have much wheel time with the revo but I'm sure the bearings would eventually suffer. They are the ones that thetoyz sells. I can't remember the brand offhand.
I received my order in the mail today! I also went to the lhs and picked up a dx4s to replace my dx3s with some leftover gift certificates.
Sweet parts and radio!
Thanks dude!
I de anodized the blue parts and hr shock bodies tonight:
I found these
http://www.ebay.ca/itm/Traxxas-Mini-...item23272086b8
It should really improve handling. I'm not overly hard on my truck so they should be ok, I wounldn't want to bend my new CVD stubs.
these are the ones I have: 15 vs 25mm
http://www.ebay.ca/itm/Traxxas-Mini-...ht_3326wt_1071
I've made a little progress on the revo. I got the front diff in and it seems like I'll be able to use the full chassis skid from tbone racing. It will just be connected to the bottoms of both diffs only. I've come across two problems so far:
1. when screwing the driver side rocker arm down it binds the bearings up. If loosened at all it will wobble. (I've tried stock rockers and the hr ones) any tips?
2. the shock mounts on the chassis leave a nice little gap between the shock tower and the shock mount. I will add spacers to make this work it just stinks.
i had to flip the rockers upside down
Mine binded with metal bearings but once I used boca yellow seal ceramics they worked perfectly
I think upside down might through it off a bit
I'll look into getting those bearings. I was able to get the stock front rockers to work and I put the front HR rockers in the back for more travel and both don't bind now. Well I finished up this round of mods for the merv yesterday. I stayed up all through sunday and sunday night and didn't go to bed until 10 last night. This is definitely the most complicated and time consuming of all of my rc's.
I really like how it turned out as far electronics placement is concerned. I took off the bottom plates of the chassis off since I mounted my battery and esc upside down. With the full skid plate on , they will get all the protection they need. I've already taken the aluminum body post towers off in favor of stock ones. I just can't see those lasting. They do look good though.
I still need to order some springs and an aluminum servo horn for the hitec servo before I can run it (any part number for that?) . I have an integy red aluminum tranny case on order at the lhs and I plan on getting more red aluminum. with all the work put into this so far, i think I'll be happy with having this a shelf queen and for street use only...I do have enough parts to get started on building another merv but then I would be going against my new years resolution of no new builds this year...modifying my current fleet is the only thing allowed lol
Nice! Try 10774 ofna tower hobbies for the horn
thanks! what pistons are you using in your HR shock bodies? I took the ones from the gtr shocks and they are slightly too small and allow fluid to go on all sides. I tried 2000 cst diff fluid and I still have no dampening.
I use the traxxas 1/16 onroad pistons. They have smaller holes. I don't know the part number off the top of my head
What shock body?
here are some more pics I took today:
front rocker arms in the rear. they almost touch but don't
had to use the extenders for these wheels
I ended up going with 100k diff fluid in the rear shocks and 60k in the front shocks. They have some dampening now but I would like to find some pistons made for the bigger bodied shocks like hr and gpm
I haven't touched this truck since the last post. I finally installed the servo horn (which was the only thing I needed for it to run) along with green rpm arms. I re-shimmed the knuckles and it was ready to go. I took it out for about 5 minutes and wasn't happy with the speed of the velineon. I haven't installed a big block yet because i didn't want to lose the rear sway bar but I said heck with it. I got the 7700 (2pole) installed today but something is not right.
When I free spin the wheels it seems like there is a ton of juice (on SPC 2s 2500 50c geared 50/28) but when I put it on the street it only goes about 20-25mph. The temps were 95-sv2, 105-7700 and 90-battery after 10 minutes or so. I then put the Traxxas 3s battery in and it seemed like it was performing the same about 25mph tops. Temps on 3s where 112-sv2 167-7700 and 115-battery. Any ideas of why the performance is so low? What is optimal gearing for the 7700?
Anyways here are some pics from today of the upgrades:
With the 7700
It doesn't look like I'll be able to use the sway bars unless I use a much taller gear.
That's the T-Bone Racing 3-piece chassis brace & skid plate kit.
IMHO it's a must have for people who are hard on their basher.
I'm using this kit plus the wheelie bar but it's not installed. http://t-bone-racing.net/Brand-N-Z/T...Revo-p431.html
The shocks consist of Hot Racing shock bodies and gtr pistons and shafts.
I've noticed that this truck like to flip over a lot with the response pros and the dirt hawgs....and its not that great in the grass so I spend most time on the street. I think i'm going to run the ken block wheels and tires on 3s only. I'm going to try it out tomorrow.
the piston doesn't seal around the shock body. thats the problem I had with GPMs and was told that the HR bodies with GTR pistons work great together but they don't
thanks for the pics
Hate to think about the $$'s that lot cost ya![]()
