Results 1 to 26 of 26
    Arizona
    119
    Slash 2WD VXL Cooling Fans
    Questions about cooling fans for the 2WD slash. i have the velineon cooling fan that goes on the esc, and i would like to get some kind of fan for the motor, because its been getting pretty hot recently. does anyone know what will fit on the motor to cool it down, and how to wire it?
    South Jersey
    696
    Quote Originally Posted by sixty2 View Post
    this is all i could find
    http://www.ebay.com/itm/Hot-Racing-B...item1c2eaa4f0a
    Anza Slash & a pile of Parts
    RC Racer armorred_slash's Avatar
    frazeysburg ohio
    192
    isnt there a version with 2 fans on the heat sink for the vxl?
    Arizona
    119
    that does look like it would fit on the motor without cutting anything. the clips dont look as wide as others i've seen. do u know how it wires?
    South Jersey
    696
    no i dont but you have the ESC cooling fan if you do just wire it to that simple and easy
    May 2009
    Copenhagen, Denmark
    167
    For suggestions on how to run your Slash cooler take a look at this thread posts #85 and #86.
    Anza Slash
    Anza Slash
    Arizona
    119
    thanks. i'll prob get the fan and motor heatsink plate from the other thread. its gettin hot outside.
    Michigan
    7,793
    Still waiting to see how the rpm case works,I did get a chance to try it out on an indoor track,the temp had to be around 60 degrees inside,and i pushed it hard,and never got over 120,so ad 40degrees out doors to that, and call it 100 degrees,you got 160 degree motor, Theoretically,I think I will need some extra type of cooling for the velineons,however the 3800 4 pole castle's never went over 100 degrees,no matter how hard I run them.
    Arizona
    119
    i got the hot racing cooling fan and it fits just need an extension so i can plug it in
    SanDiego, CA
    996
    will that fan fit w/ the rpm hybrid case
    SanDiego, CA
    996
    @sixty2 can you post a pic of the fan installed
    South Jersey
    696
    Quote Originally Posted by XRated View Post
    yes it will fit the RPM case is the same as the Traxxas case just different in the way it mounts
    Arizona
    119
    i dont know how to post pics, but i an try to explain it. i screwed the fan onto one of the clips so it fit on the motor. because the wire isnt long enough, i ordered a jst extension so now it just plugs into the receiver.
    57
    PM me and I can post/host the pictures for you and put them up here if you'd like.
    I would like to see how these get installed and fit on a Velineon setup as well...
    Thanks!
    Arizona
    119
    Arizona
    119
    tell me if this helps. try right clicking the image and opening in a new tab.
    SanDiego, CA
    996
    Oh yea so you had to take off the other half of the heatsink?
    Arizona
    119
    ya it comes with 2 clips that go around the motor. to get most of the fan over the motor you can only use one.
    SanDiego, CA
    996
    I ordered the hr solid 30mm one I measured and I'll probably have to take just a little off the tranny casing and mount the fan directly on top of the heatsink I'll post pics when I get it done
    57
    So did you just get an extended lead to power this from the receiver?
    Thanks for "sort of" posting the picture.
    SanDiego, CA
    996
    I'm waiting for it in the mail should be here mon. or tues. then going to see how I'm going to fit it and go to my lhs for and extension, I'll be posting pics and how I did it when I'm done
    Arizona
    119
    this is what i got so it could connect to the receiver
    http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
    South Jersey
    696
    are the clips the heat sink will both work after the wires are extended
    Michigan
    7,793
    With the exception of the sticker on top,the hot racing fan and the name we all know to well,this could be the same manufacture.
    [IMG][/IMG]
    Arizona
    119
    the clips do look like they are supposed to act as small heat sink. you can fit both pieces on, but then a lot of the fan is not over the motor or the clips are pretty much under the fan.
    Michigan
    7,793
    Took the fan off,ground off the three fins between the fan mounts for the motor wires,and it fits like it was custom made on the stock rpm case.
    Oh ya,I cut the first one of the four sink mounts,so they wouldn't hit the wires.
