    Dec 2014
    Goshen, IN
    slash loses conection
    If the little silver tip of my antenna got broken off will that cause the truck to not respond to the controller?
    RC Qualifier Panamon Creel's Avatar
    Oct 2014
    Central Mexico
    427
    Possibly, but for sure range will be greatly diminished
    Toronto
    196
    definitely, put fresh batteries in the tx/rx and range test it.
    Jato 3.3 Pede 2.5R Rusty 3.3
    Jan 2014
    Ohio
    809
    The little black wire that is left is a small coaxial cable. you can strip the outer black part off about 3/4" and the iner clear cable with a wire in it will work fine as an antenna. I have done this on several and all worked fine.
    It is a delicate cable so if you know someone good at delicate things they could be of help. Don
    Oct 2014
    Central Mexico
    427
    Quote Originally Posted by dontrinko View Post
    Stock the unshielded exposure is about 29mm (1 9/64") which is a touch less than theoretical 1/4 Wavelength for 2.4 GHz
    Dec 2014
    Goshen, IN
    It worked thank you!
