    Oct 2012
    60
    gear suggestions
    currently runnin 20/86. temp was to high, 170, and that was on the street no body, and o.a.t. (outside air temperature) of 62. and i was runnin alias tires on the rear. i normally play in the sand with and run the badlands tire or sandpaw tire. both of those tires have about 5in. total diameter. what size pinion gear(s) should i get to lower my temps in a better range? or do i need to start swapping spur gears. is so what gear should i go up to or down? i dont gear much about top speed. im more of a basher, and maybe once in awhile ill go to the track.
    Delaware
    1,178
    16/86 or 20/90 would be a good place to start. 170 isn't way too hot... Just a little bit hot. Traxxas says 200 is too hot.
    Sent using 8.4 volts of NiMH power!
    To the men and women of the US military, thank you
    South of St Louis
    6,369
    I assume this is the velineon esc/motor? Those tires (5") are pretty tall which are raising your gearing, plus when they balloon it goes even higher. Instead of gearing down I'd go with a heatsink or aluminum transmission to lower motor temps. 170 isn't to bad but I wouldn't let it go any higher; I start taking action at 155 or 160F.
