Results 1 to 23 of 23
    15
    Revo 2.5r motor upgrade for basher build
    Im stuck on these three engines for my revo 2.5r upgrade/basher build.
    1.http://www.amainhobbies.com/product_...e-w-Pull-Start
    2.http://www.amainhobbies.com/product_...e-w-Pull-Start
    3.http://www.amainhobbies.com/product_...in-Start-Combo
    I really dont wanna have to do a ton of work to get one of these to fit but I don't think it will be that bad and if anyone could recommend a pipe and header that would be awesome thanks guys
    Edmonton, AB Canada
    485
    Easiest one to fit would be the picco.. It has great power for your revo.. Add a rear mounted ERCM pipe with it and hang on
    15
    Thanks for the reply the biggest thing I have a question over is the thorttle linkage how to unhook it from the carb and set it
    back up
    Edmonton, AB Canada
    485
    Have ever taken the engine of the chassis?? Or sealed a carb?? How bout change engine bearings??
    15
    No lol but I get how to except the throttle linkage i just dont wanna put it back together wrong or something
    Edmonton, AB Canada
    485
    I understand that, you could search for a thread on how to.. Look for vid.. Lots of info out there. If you go with the picco .26 you can use the same linkage you have now , just have to adjust it. Make sure you zero your servo before you put the horn on tho.. The big blocks on your list will take a lot of work to get a good linkage setup..
    north east iowa
    148
    If you want to use a pull start big block motor you'll need the new era big block mount which is hard to come by. Otherwise your stuck with using a bump starter. The picco .26 and mount can use a pull start also.
    If it ain't broke, fix it till it is! BB Revo
    15
    could i throw a hpi roto start on it and also im thinking this pipe http://www.amainhobbies.com/product_...-Hard-Anodized
    Edmonton, AB Canada
    485
    Depends on which engine you choose...for the rotostart and pipe choice.
    15
    im thinking the picco supposed to be a drop in should I get the traxxas big block convertion or just the ofna mount you think? i also dont know about the Dynamite pipe or a THS rear mount
    http://www3.towerhobbies.com/cgi-bin...&I=LXLDM3&P=ML
    Edmonton, AB Canada
    485
    You have to get the ofna mount for the picco! There is another mount on ebay that's made for the picco.26 it's better cause it gives more adjustment for gearing choices..don't get the traxxas mount for the picco! I would go with a good rear mount pipe cause the picco .26 is a mid block..
    15
    Sounds good, is this the mount thanks for the help guys
    http://www.amainhobbies.com/product_...ine-Mount-Revo
    Edmonton, AB Canada
    485
    Yes that's the mount for picco.26
    Jan 2010
    NORCAL
    632
    I run that picco Red Dot, it's very nice.It's got a ton of power you realy don't need anything bigger.It goes in easy with that ofna mount.The exhaust I run is the trinity.It's loud, most run the THS.
    nutty like a squirrel turd....!!!!!
    Dawson creek bc
    1,115
    Quote Originally Posted by Ckeithnitro View Post
    Have ever taken the engine of the chassis????
    Wierdest question ever. I thing your missing like Two nouns a verb land a pro-verb.
    1,996
    Quote Originally Posted by Kyleb View Post
    You capitalized the word two, spelled "thing" instead of think, "land" instead of and, and forgot to use these,,,,,,,.
    Edmonton, AB Canada
    485
    Quote Originally Posted by lubecakes View Post
    thanks lubecakes.. kyleb can just keep it to him self!! he talks down to users , doesnt he have nothing better to do than spell checking.. lol
    15
    Any one have a way to put a roto start on the picco
    I seen a thread on it but none of the links for the required
    Parts worked and I already have the roto start handheld
    Edmonton, AB Canada
    485
    Yes here's a couple options ofna part#ofn50010 uses the hex from the pull start. Ofn50007 uses traxxas one way bearing
    15
    So to clarify If I buy Ofn50007 I just buy a trx one way bearing and put it in the backplate gear ?
    Edmonton, AB Canada
    485
    Yes.. Did you buy the picco?? Did it come with a pull start?? If so there is a OWB there already.. Hex shape. The ofn 50010 works with that OWB..
    15
    o so if i buy the 50010 i dont have to do anything just bolt up? and no im buying everything slowly actually bought the mount
    and some other things today
    Edmonton, AB Canada
    485
    Yes pull off pull start and put on the rotostart..
