Results 1 to 15 of 15
    Arkansas
    527
    Lowering My Body Height????
    I wanted to know who has lowered the body height of their Summit. I was thinking about dropping mine a ” or so, just enough to bring the body down closer to the batt doors. I realize this is all personal preference but wanted input before I cut the post off and had to buy more. LOL
    The only negative I can foresee is that I would have to flip the bumper mounts over which in return would lower my bumper height the same…….which may cause an issue when approaching an object????
    Any thoughts would be appreciated. And as the saying goes “A picture is worth a thousand words”.
    May 2009
    Edmonton, Alberta
    3,663
    Lots of people do it. Like me
    You can get it this low without trimming the body by using Revo bumper mounts in place of the stock summit.
    I just trimmed the body as needed.
    Arkansas
    527
    Thanks for the reply........do you happen to have a different picture.......that one says it has been "deleted".
    12,314
    I lowered using RPM Revo bumper mounts... that way I improve a known weak spot at the same time.
    Arkansas
    527
    So do you use Revo mounts too?
    Edit: Oops I need to read closer........I now see "Revo" mounts in your post.
    43
    I looked at flipping my stock mounts and decided not to. Flipping the stock mounts means you will have to move or cut the front deflector for it to work. I didn't want that to happen.....
    Victoria B.C Canada
    5,468
    I trimmed my bumper instead of the skid
    Sent using lipo power
    Mountains cant stop me
    they have tried
    jonesdallas
    Guest
    I lowered mine, definitely came down like 1.25-1.5". I did need to trim a little bit off the front and rear body, but it all covered by the bumpers anyway. Also had to trim the bottom of the body posts by 3 or 4 screw holes. Like the ham sandwich mod too.
    Chehalis, Wa
    436
    I lowered mine just buy trimming the body and body posts.
    _______^_
    /______l__\____
    l_l O l_____l O l
    Arkansas
    527
    jamann....So you kept the stock bumper mounts but just flipped them over????
    And is that a stock front bumper? I've been wanting to add a shackle to mine too; is that from RC4WD?
    Victoria B.C Canada
    5,468
    Quote Originally Posted by BlackSheep800 View Post
    They are rpm mounts for the summit.
    Yep stock bumper that I hacked up a bit..lol the shackle is the smallest one i could find at the hardware store
    they have tried
    Arkansas
    527
    Well i have to ask........how did you attach the shackle OR what did you attach it to? It looks like you cut slits in the bumper and attached it through the backside; using the piece of material you left in between the slits as the pulling point?
    Victoria B.C Canada
    5,468
    Yes. I also had a piece of aluminium backer plate(that as I noticed now I forgot to put back in last time I pulled it off)it is H shaped.to add support to the area that I removed material from
    they have tried
    Arkansas
    527
    I hope you dont mind if I borrow your idea........I think it looks really cool!!!! Thanks!
    Victoria B.C Canada
    5,468
    Go right ahead I'm sure someone did it long before I did..I wanted it strong.
    I was running a 1/5 scale servo winch
    With a block and tackle so I could pull myself up really steep stuff.
    http://[IMG]http://i758.photobucket.....jpg[/IMG]
    they have tried
