Results 1 to 12 of 12
    229
    New motor in a emaxx questions
    So I was putting a emaxx together off of spare parts and the only motor I have is a 1/10 scale 4600 toro and esc. Runs great on a 3 cell doing back flips and still under 100 degrees. My question is besides heat what kills brushless motors. As long as temps are good is there anything else I have to worry about?
    9,244
    Over reving a motor and bearing failure are two more
    229
    So not a good idea to run 3 cell ?
    9,244
    Its a mid size kv motor on 3s shouldn't max out the motor but I would want to.know its max rpm because you will turn just over 50k
    229
    Where can I find its Max rpm? Have it geared at 11/68 do you think it will hit 50000 rpm geared that low
    9,244
    That is geared way too low! Depending on your tires you will hit 50000 quite quickly
    Sometimes from the specs of the motor
    Now is see! 3s is not recommended http://www.ckhobby.com/shop/?control...product_id=386
    Short course motor
    229
    I have series 40 trenchers that's why I went so low but will defiantly gear it up thanks for all the help
    9,244
    Yep.
    Some taller gearing will wake it up!
    229
    Finally quit being cheap and got a 2200 Kv toro motor and esc went from not having enough power to stupid power lol
    9,244
    glad it worked out!
    what batteries are you using
    229
    One 4 cell 30 c pack
    4,872
    correct the **** out of your post and i wouldnt post that just the specs is ok.
    Living life.
