Page 3 of 8 FirstFirst 12345 ... LastLast
Results 81 to 120 of 281
  1. #81
    16
    Hi Mitch are you running the vdk on your GTR shocks or just the revo's? I'm interested in buying the kit as I have been having ttrouble tuning my GTR's but the hobby shop didn't think the kit would work. Thanks in advance.
  2. #82
    7,176
    I'm interested in the vdk kit to. Thanks for sharing Mitch. I'm curious as to which WT shock oil you are happy with. The last time out I felt I need to beef my front springs and a heavier WT oil also.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  3. #83
    3,338
    Cool CVD's (mismatched Tekno and XO-1)
    I apologies in advance for the poor quality photos.
    Thanks to Humayray and thedreadedend for this info they provided...because I am doing a Rally GT8 build with XO-1 Steering C Hubs Axle Carriers and Caster Blocks rear...I followed the mismatched parts of the drivetrain from Humayrays build thread.
    I have mismatched the Tekno dogbone and diff output drive cup with the XO-1 stub axles and CVD rebuild kit. What was required to do achieve this was as follows:
    (1) TKR6851X – M6 Driveshafts and Steering Blocks for Slash/Stmpd 4×4 (front, 6mm)
    (1) TKR6852X – M6 Driveshafts and Hub Carriers for Slash/Stmpd 4×4 (rear, 6mm)
    (1) TRA6454 Stub axle, front, 6mm (steel-splined constant-velocity driveshaft)
    (1) TRA6453 Stub axle, rear, 6mm (steel-splined constant-velocity driveshaft)
    (2) TRA6757 Rebuild kit, steel-splined constant-velocity driveshafts
    It worked out cheaper for me to buy the whole Tekno CVD kit instead of buying just what I needed...the way I am going I have enough spares to build another Rally...I've been toying with the idea about maybe building my son Ciarán a Rally.
    Here is a comparison of the front Tekno stub axle to the XO-1. As you can see the XO-1 is longer.
    Here is a comparison of the rear Tekno stub axle to the XO-1. As you can see the XO-1 is longer.
    TRA6757 Rebuild kit, steel-splined constant-velocity driveshafts...2 rebuild kits were required to complete for front and rear.
    I turned the rubber boot inside out and slipped over the ball joint of the Tekno dogbone. It was relatively easily to do.
    I applied a small amount of grease to the inside of each stub axle since this joint is a mechanical moving part that will create heat from the friction of the ball joint movement.
    And here a set of CVD's complete and ready for installation.
    Rock n Rolla !
  4. #84
    3,338
    Cool Diff Output Drive Cup.
    I thought I would share this info...I have been doing this on quite a few of my builds where it fits.
    What I have done here is put an o-ring between the Output drive cup and the diff to take up the free space and also add a bit of a seal around the bearings. This was done to all 4 diff output drives....I don't know how well it works but it is something i have been doing for some time now.
    Rock n Rolla !
  5. #85
    3,338
    Quote Originally Posted by cmoshea View Post
    Hey mate...I am running a VDK kit in my eRevo, eSlayer Pro 4x4 and now my Rally. I am not sure why the Hobby shop said that to you.; in my experience I have found that Hobby shops don't always know everything and sometimes lead you blindly in the wrong direction.
    My experience with the VDK kit has been through trial and error on my various build...What sort of issues are you having with your shocks??
    In my eRevo I am running VDK #2 front/rear...valve on top to control compression with 60W shock oil.
    In my eSlayer Pro 4x4 I am running VDK #3 Front and VDK #2 Rear...valve on top controlling compression with 35W shock oil.
    Using the VDK pistons has given me the ability to fine tune my shocks...there is also nothing stopping me from drilling the piston hole sizes bigger if need be.
    Rock n Rolla !
  6. #86
    16
    Quote Originally Posted by MITCH316 View Post
    Thanks for confirming looks like I'll be placing an order for the kit.
    For the driving I'm doing I'm finding the GTR's could use some additional compression. On the stock shocks I went with heavier weight fluid but felt like I got the compression I wanted but at the sacrifice of rebound. So when I saw the VDK it seemed like it would help get more compression without sacrificing rebound.
  7. #87
    3,338
    G'day mate...I originally had planned to use 50W shock oil on this build, but once I had installed the VDK in the shocks with my selected piston size, I felt that 50W shock oil was to thick IMO for my Rally road build...I changed the oil out to 35W as I am wanting faster shock compression.
    I am using VDK #3 Front and VDK #1 Rear as I want a slightly softer suspension in the rear. I plan to control this with the piston I have selected and spring rate while leaving the shock oil the same in the front and rear shocks. Because I am controlling rebound I am using the valve on the bottom.
    My desired result is that I want my Rally to hug the road under acceleration and cornering...I am still thinking that 25W shock oil may be the way for me to go. I will fine tune this with some heavy testing.
    If my rally were an offroad build then I would look at a 40W to 50W shock oil with a heavier spring for faster rebound...this may still be to heavy as the Rally is so light compared to my other trucks.
    Using the VDK is noticeably different even when squeezing (compressing) the shocks by hand .
    Rock n Rolla !
  8. #88
    3,338
    Cool XO-1 17mm Hex Adapders
    I am using the XO-1 hex adapters on my Rally build to give me the extra length in my drive train...so my overall wheel base width has increased with the offset adapters.
    My initial thought of the XO-1 hex adapters...they remind me of the 6mm offset 17mm Integy hex adapters I use on my Summit. They look good and the fact that they use a hub retainer means there will be less wheel slop.
    Parts list:
    (4) Splined Wheel Hub 17mm 6061-T6 Aluminum (Part # 6469)
    (4) Splined Wheel Nuts 17mm (Part # 5353)
    (4) 17mm Hub Retainer (Part # 5854)
    Its a relatively easy and straight forward install...as seen in the pic, I have fitted the splined wheel hub over the stub axle and am fitting the hub retainer.
    And here in place fully assembled.
    My build progress so far...it's going slow, it took me a while to get my head around the re-build as I am so use to working on the eRevo platform rigs I have.
    The Rally is actually a very easy rig to work on...I am liking the Rally design very much .
    Rock n Rolla !
  9. #89
    The Mitten
    1,685
    Many I need that setup for my Rally. Looks great man
    Everything overpowered...
  10. #90
    7,264
    did you recieved your xo-1 wheels/tires? those tires are alot bigger (diameter) than the one i'm running and your probably going to cut the wheel well on your body even bigger than usual.
    i know i said it before but, i'm going to say it again.......Love the write-up very informative.
  11. #91
    Delaware
    123
    Looks great, those adapters are a nice fit.
    and i thought the pics look good......
    now get back to work!
  12. #92
    3,338
    Quote Originally Posted by QYKSLVR View Post
    Quote Originally Posted by JackSlash View Post
    Looks great, those adapters are a nice fit and i thought the pics look good......now get back to work!
    Cheers guys, thanks for the feedback.
    Rock n Rolla !
  13. #93
    3,338
    I got them mate...They measure 110mm in diameter; how does that compare to yours??
    I do know that they are slightly smaller diameter than my 1/8 buggy wheels I have on my eSlayer Pro 4x4...I've compared the heights of them next to each other...not by much tho.
    Rock n Rolla !
  14. #94
    7,264
    i did'nt get no XO-1 wheels&tires yet but, it seems a lot taller compare to my buggy wheels&tires. my buggy stand at OD 3.8" while XO OD 4.29"
  15. #95
    3,338
    Those wheels are a fair bit smaller...hopefully it will work out mate ...110mm vs 97mm, that's 7.5mm higher around the wheel well area .
    Rock n Rolla !
  16. #96
    3,338
    Cool Slipper Clutch.
    I have decided to run a double slipper that is for the eRevo on this build...I don't know how well it work but my thinking is that the MMM powers an eRevo very well...I thought that the stock slipper was a wee bit on the small side for my liking powering the MMM 2200kv combo.
    I am using graphite slipper pads on this slipper assembly...I have never used them before or have heard much about them either. They look good tho...I'm hoping with the 2200kv motor that this slipper assembly will work like a treat.
    Parts needed for the Slipper assembly:
    1 x Hot Racing Power Double Up Slipper System Large #TRX15GP
    2 x Graphite Slipper Clutch Kit #TRX15GS
    Hot Racing Power Double Up Slipper System.
    Here is the opposite side for reference.
    Graphite Slipper Clutch Kit.
    Here is a comparison of the stock slipper to the Hot Racing power double up slipper...I took the wear plate (slipper disk) from a brand new eRevo slipper clutch rebuild kit #5352R I had lying around.
    And here assembled with the graphite slipper pads.
    I had to replace the 2mm pin as it was too short...I used one of the pins that I got with my Tekno CVD kit as it was the right length that I was after.
    I also used the second hole on the input shaft.
    Remember when assembling that the spur gear # faces outward as seen below.
    Here is a side view of the slipper assembled.
    TRX15GP Power Double Up Slipper System Large
    This is a Power Double Up Slipper Pressure Plate and Slipper Hub for the Revo, T-Maxx Summit, Long Chassis e-maxx, 4x4 Slash Etc.
    These are a part of the slipper assembly.
    FEATURES:
    CNC Aluminum construction with Hard Anodizing.
    Allows you to double up the slipper surface to increase power transfer.
    YOU WILL RECEIVE:
    One slipper pressure plate
    One slipper hub
    REQUIREMENTS:
    Installation onto vehicle.
    COMMENTS:
    This replaces TRA5351
    NOTE:
    For double the slipper surface order 2 sets of TRA5352X, TRX15HS, or TRX15GS
    Rock n Rolla !
  17. #97
    Jun 2010
    Springfield, Ma.
    3,377
    Nice work, its all gonna come together nice! The axle set looks like it all went together well for ya too. Maybe some others will brave the unknown, as you've showed, following directions can pay off! I get a awesome feeling after completing a mod for the first time. The harder the mod, the more empowering It feels after I finish. Great work, and excellent write up to follow.
  18. #98
    7,176
    Nice man. I like that upgraded slipper setup from HR. Man that adds3 more shoes and a huge biting area. I changed my Slash 4x4, Pede 4x4, & 1/10 Rally 4WD to the Revo Slipper and alloy pads. I feel it works better vs the stock on big power.
    Let us know the difference of it over stock. That should be totally awesome for sure.
    Very good work indeed.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  19. #99
    3,338
    Thanks mate...thanks for the info you and Humayray provided for the CVD mod. It took me a while to get my head around but wasn't to bad in the end. This Rally build is something new to me...it is my first non-eRevo platform truck...I like it, it really simple to work on .
    Rock n Rolla !
  20. #100
    3,338
    Thanks mate...I'm really looking forward to giving my Rally a blast. I am still working on some of the mods. I am also thinking about adding a couple more limiters to the rear shocks. I'm hoping the slipper was a worthy upgrade for the MMM 2200kv combo.
    Rock n Rolla !
  21. #101
    7,264
    i'm glad your liking it even more, you'll have a blast running it once its done, thats for sure. and we give all that credits to thedreadedend as he too show me how its done
  22. #102
    Jun 2010
    Springfield, Ma.
    3,377
    Well, if you've done a lot of mods to your revo, theirs little to nothing that'll slow ya down here. I think tire mods and this axle mod is about as tough as it could get lol! Not bad at all Haha.....
    Before Tekno jumped on board with the protrac set up, I was at a loss...... having xo1 sets, (need the carriers, knuckles, hubs.....)Tekno sets, (needing its matched carriers knuckles and hubs...)and being happy with both, I didn't want to invest in another full suspension from mip too. Id need a full set of stock sized carriers, knuckle and hubs lol. Proline had been advertising mip for protrac so I grabbed up all my parts to see what I could do about an extended axle/shaft set.
    That's how that mod was born lol.
  23. #103
    3,338
    Cool Slipper bearing adapter
    I have upgraded the stock slipper bearing adapter to the beefier aluminium King Headz slipper bearing adapter.
    King Headz slippr bearing adapter # TRX6893
    Again a comparison of stock to the King Headz sipper bearing adapter.
    Slipper clutch fully assembled and ready for installation.
    TRX6893 - Slipper Bearing Adaptor
    FEATURES: This bearing adaptor is CNC machined
    from 7075 grade aluminum. This directly replaces the
    plastic TRA6893 bearing adaptor that tends to have a melting problem.
    INCLUDES:
    (1) Bearing Adaptor
    SPECS.
    Material: 7075 Aircraft Billet Aluminum
    Weight: x.xx75 grams
    Rock n Rolla !
  24. #104
    3,338
    Cool Mod 0.8 vs Mod 1 Gears.
    I am running Mod 1 gearing in my Rally build. I am going to start off with 21/36 to see how that goes. I've been running Mod 1 20/38 in my eSlayer Pro 4x4 and absolutely dig Mod 1 gearing .
    Here is a comparison of Mod 0.8 21T Pinion against a Mod 1 21T pinion
    A 54T Mod 0.8 is the smallest Mod 0.8 spur I have....here is a comparison against a 40T Mod 1 spur.
    A close up so you can see the different gear mesh.
    Rock n Rolla !
  25. #105
    3,338
    Cool Aluminium Diff Cup.
    This is the new Hot Racing diff cup.
    Below is a pic of the old diff cup (the black on the left) compared to the new one (the blue on the right).
    The new screws are longer than what came with the old HR diff and they have replaced the countersunk screw head with the BHC screw which is used on the stock diff cups.
    Hers is a comparison of the internal of the 2 cups...as you can see the new one (blue) resembles a stock cup. As you can see they have reworked the mould for the internals of the cup.
    What is nice about the new HR diff cups is that there is NO MODS necessary to fit the I-bar into the cup. As seen below it is a direct drop of the the spider gear system into the diff cup.
    Hot Racing Aluminum Differential Case for the Traxxas Revo trucks. (in place of Traxxas 3978) This differential case features a 6061-T6 aluminum body
    FEATURES:
    CNC Aluminum Construction diff case
    YOU WILL RECEIVE:
    (1) blue Aluminum Differential Case
    (4) screws
    REQUIREMENTS:
    Steel axial guide and gasket that comes with the plastic diff case
    Stock Gasket from (TRA3978)
    Installing gear set and attaching to bevel gear
    Thread locking adhesive to keep screws from loosening due to vibration.
    SPECIFICATIONS:
    Out drive plate length: 9.5mm
    Diameter 24.3mm
    Diff. Case
    Length: 14.0mm
    Diameter: 25.5mm
    NOTE:
    This replace TRA3978 make to work with TRA5382X diff gear set. Do not over tighten Use only Silicone diff lube
    Rock n Rolla !
  26. #106
    7,176
    Yo man. I really like that HR diff cup. Thanks for noting the difference between the 2. Good info like that helps fellow RC'ers.
    Thanks a bunch. I might do that in the future.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  27. #107
    Oklahoma City, OK
    2,700
    i wouldnt want to see the price tag on this Gem! Looks SUPER!!!
    "RED"
  28. #108
    3,338
    No worries mate...I'm glad the info provided was useful .
    Thanks mate...this build has gone well over the intended budget. I'm really stocked with it so far.
    Rock n Rolla !
  29. #109
    3,338
    Cool Diff Shims.
    These are the shims I am using now to shim my diffs and anywhere else on my rigs that need shims...these are from 3 racing; what''s nice about these shims are that they come in 3 different thicknesses (0.1, 0.2 & 0.3).
    6mm Shim Spacer 0.1/0.2/0.3mm Thickness 10pcs Each - 3Racing 3RAC-SW06
    8mm Shim Spacer 0.1/0.2/0.3mm Thickness 10pcs Each - 3Racing 3RAC-SW08
    10mm Shim Spacer 0.1/0.2/0.3mm Thickness 10pcs Each - 3Racing 3RAC-SW10
    12mm Shim Spacer 0.1/0.2/0.3m Thickness 10pcs Each - 3Racing 3RAC-SW12
    Rock n Rolla !
  30. #110
    BNE
    704
    Nice idea with the different thicknesses. Will make getting the optimal shimming a lot easier. Definitely gonna have to "borrow" some of those
    Always get a 2nd Opinion!
  31. #111
    3,338
    Cool Diff Build and Shimming.
    For my diff build I have used the Traxxas diff lubes.
    Front diff I used 50K diff lube and for the Rear diff I used 30K diff lube.
    I filled the diff cup to the top with the diff lube and removed as much of the air bubbles as practically possible.
    I then fitted the ring gear and tightened 3 of the 4 screws leaving the 4th one out to allow excess diff lube to escape through the open screw hole.
    And here all together, cleaned and ready to be shimmed.
    For my Front and Rear diff, they both took 1 x 8mm shim 0.3 thk on the ring gear side thus making the ring and pinion gear a tighter mesh with less play.
    The Front diff pinion gear took 2 x 6mm shim 0.2 thk pushing the pinion closer to the ring gear tightening the mesh even more.
    I then greased the ring gear with Mobil 1 red grease and closed up the diff case.
    Once together the gear mesh was relatively smooth...Lubing the spider gearsinside the diff cup, shimming and greasing the ring gear is not too difficult and fairly easy to do.
    For the Rear pinion gear you would need a 12mm shim...I found that I didn't need to shim the rear pinion as gear mesh and play was relatively good. I may end up putting one 12mm shim on the rear pinion once I have broken the diffs in after a good few solid runs.
    Rock n Rolla !
  32. #112
    3,338
    Cool Diff lube effects.
    A little bit of info on diff lube...From my experience this is my understanding of diff lube effects....
    Front
    Thinner diff lube:
    • Increase steering into corners (off-power).
    • If the lube is too thin the steering may become inconsistent, it can loose forward traction (and steering) during acceleration out of corners.
    Thicker diff lube:
    • Increases stability into corners during braking.
    • Increases steering on-power at corner exit.
    Centre
    Thinner diff lube:
    • Front wheels unload more during acceleration.
    • Decreases on-power steering (reduces over-steer).
    • Easier to drive on rough tracks.
    Thicker diff lube:
    • More all-wheel drive effect.
    • Better acceleration.
    • Increases on-power steering (reduces under-steer).
    • Better suited on high-bite, smooth tracks.
    Rear
    Thinner diff lube:
    • Increase cornering traction.
    • Increases steering into corner.
    Thicker diff lube:
    • Decreases rear traction while cornering.
    • Reduces wheel-spin.
    Rock n Rolla !
  33. #113
    3,338
    This is the Red Mobil grease I have been using lately...(it must be good stuff, it's endorsed by NASCAR )
    It is a lithium based synthetic grease...I use it for greasing the diff ring gear and bearing maintenance.
    Rock n Rolla !
  34. #114
    Glens Falls New York USA
    653
    Great thread Mitch. Thank you for sharing all of this useful information with us. Hope you keep posting all the details. Iv been following.
  35. #115
    3,338
    Cheers mate...thanks for the feedback. I am glad you find the info provided useful .
    Rock n Rolla !
  36. #116
    7,176
    Very good work!!! Can I send ones from me EMBE, ERBE, Slash 4x4, Pede 4x4, and 1/10 Rally 4x4. Oh and my little guys MERV?? LOL j/k
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  37. #117
    3,338
    Thanks mate...I appreciate the feedback .
    Rock n Rolla !
  38. #118
    3,338
    Cool Mounting hardware for front and rear shock towers.
    Again I apologies in advance for the poor quality photos in this section.
    I've tried to make do with the screws and nuts that I have on hand in my tool box instead of purchasing new ones to suite my build.
    Mounting the shocks to FRONT and REAR shock towers.
    I have used the 3 x 32 CS that is used for mounting the eRevo shocks to the chassis.
    I then took 3mm flanged nuts that I had lying around that came with the Savox servos I have on my trucks.
    I threaded from the opposite end to where the shock mounts so the flanged nut will be on the shock end.
    I fastened the spacer (collar) as tight as I could then mounted the shock and fitted the nut to the end. I like to have a couple threads protrude out from the nut.
    Front shock tower.
    Rear shock tower.
    Mounting the camber links to FRONT and REAR shock towers.
    I never measured these but I think they were 3 x 18 BHC screws...again I used the 3mm flange nuts I got with the Savox servos I have.
    Front shock tower. Before
    As you can see above the BHC screw is too long for my liking...as said before I like to have a couple of threads protrude out from the nut. I used the cutting disk on my dremel and cut back the BHC to my liking...this was done with the BHC assembled in place as per the photograph.
    After
    Rear shock tower. Before
    After
    My build is progressing nicely...I am very happy with it so far...it is also the neatest of all my builds so far. This rig wont see any dirt as it is built for street use only...
    Rock n Rolla !
  39. #119
    BNE
    704
    Another gr8 build thread mate. Keep those informative posts coming.
  40. #120
    3,338
    Cool Mounting hardware for C Hubs Axle Carriers and Caster Blocks rear.
    I have done a similar thing to my shock towers...I have used a normal 3mm nut instead of a flanged nut. I never measured the length of BHC screw I used.
    FRONT Steering link mounting.
    REAR Caster link mounting
    Rock n Rolla !
