Results 1 to 10 of 10
    Santiago
    80
    Fuel consumption and time
    Hey guys, that's my question, how much time are you getting from your tanks? i'm getting like 5 or 6 minutes tops, and if i do like 4 or 5 WOT passes in a 55 yards straight line, i get like 3 mins
    is this a standard or should i get more time from a 75 cc tank?
    Cheers
    Daniel
    Jun 2010
    Miami, Fl
    6,731
    That's about the average. I would like to see a bigger tank available.
    20
    im pretty sure i get way more than 3 minutes. I've never actually timed it but maybe your running rich or have a leak in the tank or fuel line?
    Santiago
    80
    hmm divided opinions, we need more input
    Santiago
    80
    no leaks, maybe i ran too rich, i'll chek again this weekend
    20
    If your running that that rich where your getting only 3 minutes. You'll probably see fuel spit out of the exhaust or maybe turn it sideways and it'll just leak/pour out
    Santiago
    80
    Quote Originally Posted by Zwiff757 View Post
    when i do the after run maintenance, i se fuel pour out from the exhaust... definetly too rich then
    tunning weekend yaayy u_u
    You are too rich, check idle aswell. We got 1hr 30 mins out of 800mls of 20% fuel now its finally tuned right.
    Ours ran like you say and excess fuel from exhaust before tuning properly which meant LS and HS and idle all changed from stock. After run-in of around 3 litres.
    Santiago
    80
    i'm gonna go back to stock, and tune from scratch.
    aside from that, i recently changed the spur gear, do you guys know wich was the stock tightness of the spur? i think mine is a little loose, and don't want to overtight it
    80
    CR,
    A couple suggestions. After tuning, you might try adding an extra fuel tank, I did it and it works great. Youtube video (Jato, adding extra fuel tank) as search words and it walks you through; easy peezy. The spur gear should be tightened to where the spring is stacked w/out gaps then out 1/4 turn or so (from the manual). Hope this helps.
