Thread: sand tires
    sand tires
    hi does anyone know what sand tires will fit on the slash nitro i was looking at the proline sling shots but they look like they would require body modification... does anyone know if they fit or of any other sand tires that would
    5,642
    Welcome to the fourms! The best sand tires I can think like you said is the Pro line Sling Shots. http://www.rcplanet.com/Pro_Line_Sli.../pro115800.htm Or you can get the front tires with them as well. http://www.rcplanet.com/Pro_Line_Moh.../pro115700.htm Other than that, there really is no good short course truck tire that works as well. Hope this helps!
    do they require body modification to fit?
    442
    I dont think so I just looked at the ones off of google for the slash and it looks like they just raised the body posts so you should be fine.
    naptown
    592
    Panther has some sand tire paddles also you might want to check out also...check out rc4wd.com pretty sure they have some other paddle tires on there too..
    Edmonton, AB Canada
    485
    just got a set of panther paddles SC the paddles are much larger than proline slingshots SC
