Results 1 to 14 of 14
    USA
    571
    Traxxas aluminum caster block question...
    I currently have the traxxas aluminum caster blocks (part num:6832X) on my 4x4 stampede.
    Here's my question:
    Can the aluminum caster block fit on the Tekno steering blocks (See pic below):
    If the traxxas aluminum caster blocks doesn't fit, what aftermarket aluminum caster blocks can I use to pair it with the Tekno steering blocks?
    Thanks in advance guys!
    Last edited by stampede_fanatic; 02-09-2013 at 03:24 PM. Reason: Corrected typos...
    United Kingdom
    874
    I would guess so as the ally castor block is a direct copy of the stock one is it not? May want to wait for further confirmation or email Tekno RC. :-)
    Nov 2011
    Portland OR
    381
    From what I've seen your only choice is the plastic tekno's.
    USA
    571
    Quote Originally Posted by o0wiz0o View Post
    Hmmm, if you think about it your right since the stock traxxas caster block fits directly over the Tekno steering blocks and the alum traxxas caster block is a direct copy of the stock caster block. I'm now telling myself this... "DUH!"
    I'll try to email Tekno RC as well to confirm.
    USA
    571
    Quote Originally Posted by braaap58 View Post
    Tekno does not sell any plastic caster blocks for the stampede 4x4. They only have steering blocks and rear bearing carriers for the stampede 4x4, hence my post.
    Nov 2011
    Austin, Texas
    970
    I have strc castor blocks on mine. Works great.
    USA
    571
    Quote Originally Posted by Slaughter33 View Post
    Strc castor blocks with tekno steering blocks?
    Jun 2010
    Miami, Fl
    6,731
    tekno steering blocks are made to fit either the plastic c-hubs or the aluminum so they should work without a problem, the only difference with the tekno steering block is they use a bigger bearing so you have to use their steering block or change the bearing size if you want to use a diff steering block.
    Nov 2011
    Portland OR
    381
    Quote Originally Posted by stampede_fanatic View Post
    I spaced out and was referring to the steering blocks, yea he's right
    Nov 2011
    Austin, Texas
    970
    USA
    571
    Yup! Your right man. The Tekno steering blocks look real beefy with bigger bearings, which I like.
    Its all good. No worries.
    ^^^Thanks for the pic man!^^^
    I now know how it looks like with strc caster blocks.
    7,264
    i use all XO-1 to pair with my tekno CVD's its the only way for me to make up the lenght of PL protrac arms.
    Nov 2011
    Austin, Texas
    970
    Tekno makes bones for the protrac kit.
    7,264
    i bought the tekno kit for stock arm length purposely to make up with XO-1 stubs and carriers/C-block. if i use the protrac bone it will be too long too.
