Results 1 to 10 of 10
    Jan 2008
    548
    Resonator life span (3.3)
    is there a life span for a tuned pipe?? Just curious
    Sep 2006
    West Virginia
    505
    I don't think so. No moving parts.
    12,490
    As long as you don't crash and damage it...eternity.
    Jan 2008
    548
    Kinda what i thought. Wasnt sure if it would build up gunk in the pipe and hinder performance
    12,490
    Yeah but you could wash it out with solvent.
    Rochester,Wa USA
    213
    What would a good solvent be? Would denatured alcohol be sufficient?
    Traxxas Nitro Sport w/ TRX 3.3 Racing Engine
    Levittown, NY
    141
    carb cleaner works well i use that then coat it with wd-40
    I'm hittin' easy street on mud tires.
    Oct 2005
    19,409
    You could use denatured no problem... Also rinsing it with fresh fuel won't hurt it either...
    Plug the stinger put some fuel or Denatured Alcohol in it, plug the other side,,, shake well, let it sit for 20 minutes, shake again, rinse. I do this about every 5 gallons..
    In all actuality the pipes should perform better with age as they tend to hold heat better and a hotter pipe = more torque in most cases.
    All Lives Matter
    Gurley, Alabama
    797
    Is it normal for these pipes to keep getting louder?
    Oct 2005
    19,409
    Quote Originally Posted by Mark Ball View Post
    Humm,,, never noticed it..... The only thing that's different from when new is they now have an coil coating cooked into the metal which definitely helps them retain heat better,,, that's a good thing with 2 strokes...
    All Lives Matter
