Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Baton Rouge, LA
    1,066
    Short term gain, long term loss.
    Are you referring to the lower cut off? The ESC doesn't do it accurately. If set at 3.2, the actual voltage per cell will be about 3.5. If you set it to 3.4 it cuts off near 3.8 which is too high.
    / 16
  2. #42
    19,836
    Quote Originally Posted by jrmbtr View Post
    Are you referring to resting voltage or voltage under load?
    Alt-248 on the number pad =
  3. #43
    South of St Louis
    6,368
    I run 25% drag brake on my 2wd trucks but I when I install a MMP in my Rally or Sl4sh I probably won't run any drag brake. I figure the 4wd system will be enough drag.
    On my short street I spend as much time slowing down at the end of runs as I accelerate at the beginning.
  4. #44
    Baton Rouge, LA
    1,066
    Low voltage cutoff on that ESC doesn't seem to be accurate.
    / 16
  5. #45
    Wales in the UK
    6,462
    Quote Originally Posted by idkhow101 View Post
    Ok, i just drooped my lvc to 3.2 so it brings it back up to 3.5 otherwise it was coming out of lvc at 3.78 or so... Do you think i will be fine if i replace this slushy snow with warmer weather?
    With the new settings it will run cooler but in the middle of summer you may have to drop a tooth or two or get a good fan for the motor....peace
