Results 1 to 10 of 10
    Apr 2009
    Knoxville, TN
    2,218
    Vilenion Motor Question
    My stock motor spins freely with almost no resistance if I twist the pinion. Is this normal? All of my other brushless motors click when the magnets engage when I turn the pinion. Is my motor shot?
    Xerun 150A 2200kv ERBE
    Dewalt 14.4v Summit
    Buffalo NY
    1,330
    Quote Originally Posted by Novarider View Post
    Is my motor shot?
    Brushless motors vary greatly in terms of how "notchy" they feel when you turn them. Some shafts move without much resistance at all. If your Pede is running fine, I wouldn't worry about it!
    Apr 2009
    Knoxville, TN
    2,218
    It coggs terribly at low throttle. It takes almost half throttle to get it to move. That's why I was wondering if it's bad.
    Dewalt 14.4v Summit
    Buffalo NY
    1,330
    Ouch, now that might be a motor problem! See what the other guys say about this...
    Wales in the UK
    6,462
    That does not sound good you should take it out and put it apart and give it a once over and see if the magnets are damaged or if the bearings are shot and then report back to us dude...peace
    Apr 2009
    Knoxville, TN
    2,218
    I took it apart and the magnet was not damaged and the bearings are good to. Some of the copper wire looked like it had been moved or something. It wasn't straight it was crooked.
    Dewalt 14.4v Summit
    Wales in the UK
    6,462
    Did you give it a god clean with motor spray and lube the bearings it all helps ...peace....ps make sure there is no binding the the drivetrain as well man...peace
    Rotterdam, Netherlands
    8,559
    2 pole motors (like the Velineons) feel less notchy than most 4 pole motors. What could have happened is that you motor was overheated which can cause the magnet to lose power. Another cause of cogging can be the lack of power of the battery.
    Oklahoma City, OK
    2,700
    I was going to post the exact info as Peter....+1^^^
    "RED"
    50
    I had the same cogging issue which is very common with thesd velineon motors and mine was only two months old with temps never exceesing 140. Sent it in to Traxxas with the esc and both were replaced. Suggest you talk to customer support and see what they can do for you
