Results 1 to 12 of 12
    Minnesota
    1,335
    30th Grave Digger LED's
    I got some awesome news, after about 2 months owning this thing the LED's on the skull on one side burnt out. Anyone know Traxxas's policy on LED's? Do you think it's worth contacting them about?
    Pueblo, Colorado
    53
    Are you sure it not a wiring problem. LEDs rarely burn out...
    MrTLV
    Stampede VXL
    Minnesota
    1,335
    Quote Originally Posted by MrTLV View Post
    Looked at the wiring everything looks intact the way ti always was. When I was driving the truck they started ti flicker and then just went dead.
    Pueblo, Colorado
    53
    That makes me wonder also, when an LED burns out they don't flicker they just go out. You can connect it directly to a battery and test the individual LEDs.
    MrTLV
    Stampede VXL
    Minnesota
    1,335
    Well I'm not gonna cut it unless I can get a replacement. I'm just wondering if it's even worth trying.
    Pueblo, Colorado
    53
    You can pick up individual LEDs at any electronic store like Radio Shack. They don't cost much.
    There are ways to test the LED without cutting the wires. Can you follow the wires to the power source and disconnect it? Then reconnect it to a 9v battery. You will have to make sure you connect it with the correct polarity, if you connect it backwards it won't hurt it, it just won't work. So try connecting it both way to make sure it's not the LED (Light emitting Diode).
    MrTLV
    Stampede VXL
    Minnesota
    1,335
    Found the problem some how a wire pulled out of the plug that connect to the connector coming from the ESC. Have no idea how to get it back in and it seems like there is no way to get them out either.
    Pueblo, Colorado
    53
    I'm not sure what kind of connector that is, but there has to be a way to reconnect it. Post some pictures so we can see what it looks like.
    MrTLV
    Stampede VXL
    Minnesota
    1,335
    I couldn't get a good picture of mine but here is a picture of the plug if it helps any. But mine has 4 wires going into it instead of 2 so its pretty tight fit.
    Dec 2006
    Argentina
    4,715
    Actually, they do in some cases... But this is not one...
    He Who Dies With the Most Toys Wins.
    Pueblo, Colorado
    53
    There should be a little tab on the socket or pin that goes in the plastic connector. You should be able to bend it back out an use a small screwdriver to push it back into the connector. Good luck...
    MrTLV
    Stampede VXL
    Pueblo, Colorado
    53
    Quote Originally Posted by danielhr77 View Post
    Actually, the only way an LED can flicker is when the voltage going to it fluctuates. Since an LED doesn't have a filament they are illuminated solely by the movement of electrons in a semiconductor material.
    LEDs have several advantages over conventional incandescent lamps. For one thing, they don't have a filament that will burn out, so they last much longer. Additionally, their small plastic bulb makes them a lot more durable. But the main advantage is efficiency. In conventional incandescent bulbs, the light-production process involves generating a lot of heat (the filament must be warmed). This is completely wasted energy, unless you're using the lamp as a heater, because a huge portion of the available electricity isn't going toward producing visible light. LEDs generate very little heat, relatively speaking. A much higher percentage of the electrical power is going directly to generating light, which cuts down on the electricity demands considerably.
    MrTLV
    Stampede VXL
