Results 1 to 9 of 9
Thread: Rally-Pede
    28
    Rally-Pede
    I have a pede 4 and want to change it into a rally car. I have seen the pede to slash conversion but really don't want to go that way and have seen slash to rally also.So what do I need to do pede to rally other than wheels and body? Part numbers ,pictures of this conversion if you have them. Thanks for any help you can give!
    7,264
    so what is it you really want to do cause you said, "I've seen the pede to slash conversion but really don't want to go that way and have seen slash to rally also" and then you said, "what do I need to do pede to rally other than wheels and body" im confused? or is it the other way around?
    28
    I want to change my 4x4 stampede to a rally car using the pede chassis.
    7,264
    all you got to do is lower your truck and get the wheels/tires from rally...... the front bumper/support...but here the thing though, your pede chassis is shorter than the rally chassis.
    Nashville, TN
    2,078
    Yeah you'll need to swap to the new LCG chassis too.
    Or, you could search for a body that would fit the shorter chassis with the rally front and rear bumpers on it.
    7,264
    i seen the Jang reviews on youtube about the rally 1/10 with their sizes and all.....i think you might be able to use other rally body for that pede chassis.
    11,293
    the LCG chassis has a different rear bulkhead, front chassis brace and steering linkage. It also uses a different RX box and battery hold down setup, motor mount, motor plate... youd need all that to swap to an LCG slash/rally chassis. The pede is substantially shorter than the slash/rally so the body will not fit at all.
    Apr 2008
    Rochester, New York
    627
    Here ya go!!!
    My entire post is HERE
    6855 Driveshaft
    7426 Battery hold down
    Or 7426x Expanded battery hold down
    7436 Bumper foam
    7424 Receiver box
    7422 Chassis
    7423 Nerf Bars
    7437 Front skid
    7430 Front Bulkhead
    7438 Linkage
    7429 Rear Bulkhead
    7477 Gear Cover
    7460 Motor Mount
    7490 Motor Plate
    7415 Rear Body Mounts
    6416 Front Body Posts.
    2577 (2 packs) nerf bar screws
    3937 Screws to hold front bumper to the bulkhead
    Who needs nitro, when you got LiPo?
    28
    Thanks to all
