Page 11 of 11 FirstFirst ... 91011
Results 401 to 410 of 410
  1. #401
    May 2017
    28
    didnt even realize STRC made one. thanks
  2. #402
    Jun 2018
    11
    I purchased Slash 4x4 platinum edition. My output for the rear drive shafts, there's a lot of slop coming from the plastic bell end of the cup. When I installed mip x duty drive shaft I noticed the slop. The other end is tight without slop. I identified part #5381. I'm hoping its just a bad egg, so to speak. I'm convinced it came from the factory that way. All of the gears inside are good. I've ordered replacements 5381.
    How about aluminum differential cases from Hot Racing?
    I knew the slop was bad, but what's happened is that wiggle makes it's way down to wheel end the metal hex on my MIPs wiggles and strips the plastic hex inside tires. Two new, good tires have been ruined. The tread and tires are still awesome, but useless if inside hex is rounded.
    I hope new diff cases solve the slop and save my tires. Any suggestions or comments?
  3. #403
    Sep 2015
    2,216
    Quote Originally Posted by Axsion-Jaxn View Post
    Did you check your bearing on that side? If it's gritty/seized, the diff will be forced to spin in the bearing, which will melt/damage the plastic housing.
    I've never seen a wheel get damaged in a metal hex because of a rough driveshaft. It almost always happens because of a loose wheel nut or too tight of a slipper clutch setting (and a lot of power). I'm not saying it didn't happen to you, it just seems less likely than the other reasons.
    youtube.com/c/RazorRCvideos
  4. #404
    Jun 2018
    11
    Quote Originally Posted by RazorRC22 View Post
    Yes I did check the bearings. It just seems the diff cup has a hole that allows too much wiggle of the output shaft. The hole opposite the gear end. The wiggle goes down the left rear drive shaft.
    I had also checked the wheel nut. It did not seem to be loose when I checked. I regularly check most fasteners before and during use. I know that's a possibility. Thanks for your input.
    Do you have any feedback or knowledge about aluminum or maybe an RPM version?
  5. #405
    Indianapolis
    14,214
    You may actually want to check the MIP shafts. I have had that wiggle. It was that I was a little sloppy with the Loctite. It got into a joint and didn't allow for the full movement. I took it apart, cleaned it and put Loctite on it more carefully and the problem went away.
  6. #406
    Jun 2018
    11
    I ordered two Traxxas diff cups. At install, the plastic end held the output tightly. After a day of use, maybe three packs, all the same wiggle is there. Are my mip x dutys too much for these diff cups? I can always check the grub screws and Loctite as you suggest. It just seems like the wiggle is originating from the plastic end of the diff cup. The metal end supports the output shaft very securely.
    I'm considering Fast Lane Machine, they make aluminum diff cups and other upgrades for the Slash 4x4 LCG. Has anyone used FLM parts?
  7. #407
    Jun 2014
    Southern California
    7,576
    For a good read...
    https://forums.traxxas.com/showthrea...P-X-Duty-Users
  8. #408
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    270
    I like those...especially the cup, even though it can't be seen...I'm sure its a little sturdier than the plastic cup. Can't make myself spend that much on spiral gears though, so may have to keep using the straight stock ones.
  9. #409
    Jun 2018
    11
    You know what? Tightening the grub screws and some locktite did clean up a lot of that play. Thanks
  10. #410
    Indianapolis
    14,214
    You are very welcome! I have done exactly what you did. It is is a quick and easy fix
