x0-1 run times
What is your average run times with the stock batteries that comes with the car?
depends on gearing. I get 45 minutes. Of course im not buried in the throttle every second i run it.
Mine is unlocked, the last time i drove it, it was on 3s, 4500mah batteries, less than stock batteries.
this car is nuts enough out of the box.
the last time i ran it full bore with the stock 5000mah batteries, was about 20 minutes.
Stock 3s 5000 mah. On lower speed gearing. I get bored and put it away before I run a set of batteries dead. Atleast. Half hour plus of off and on throttle
Reason: Adding more text
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
