Results 1 to 13 of 13
    Feb 2013
    lancaster county,pa
    72
    pushrods and tierods
    Does anyone have any experience with the HR pushrods and tierods. After 3 times of use ive had 4 broken ends on my gpm. Looking for something better.
    Thanks for the help
    Jul 2011
    yankees suck
    88
    no experience with hot racing's but i can say traxxas's red aluminum one are tough
    Feb 2013
    lancaster county,pa
    72
    Was just trying to find out how well the aluminum ends would hold up compared to the plastic on other brands.
    so cal
    9,244
    I hear the aluminum ends are junk. Best to go traxxas
    Feb 2013
    lancaster county,pa
    72
    Thanks, think I'll do that. Any suggestions for axles, stock-HR- or traxxas upgrade
    so cal
    9,244
    I would stay stock until you start breaking then traxxas cvds
    Feb 2013
    lancaster county,pa
    72
    thanks 50.
    Slovenia
    321
    Feb 2013
    lancaster county,pa
    72
    Are those plastic or steel hollow balls that are included
    Feb 2013
    Auckland, NZ
    208
    7059 have plastic balls included, the steel hollow balls are 7028x (22 balls i believe)
    holliston massachusetts
    137
    I got the traxxas ones and i have not had a problem with them and they look great with their nice red color which is half of the battle at least for me
    Feb 2013
    san antonio texas
    45
    When ur buying aftermarket parts u have to keep in mind that althought aluminum parts are stronger than plastic they are also rigid. Plastic is flexible and can absorbe shock without damage. Sometimez more than aluminum. Having plasic rod ends is a petfect example. The aluminum push rod is not going to break but the plastic rod ends will flex and absorbe shock that the aluminum won't. Thats y traxxas push rods and tie rods are setup that way. Also plastic gives u a weakest link. Better to break a plastic rod end then to make it so tough the same impact breaks ur plastic bulkhead instead. Personaly I'd recomend going with traxxas parts when u can (they know what theyr doing) and use rpm parts for the other stuff. Rpm is good stuff because u get all the benefits of plastic in a beefier setup. I hope this explination helps.
    Sent from my SCH-I535 using Tapatalk 2
    Feb 2013
    lancaster county,pa
    72
    Ordered some spare gpm rod ends, see how they hold up this time. Otherwise I will get the traxxas ones.
