Results 1 to 4 of 4
    15
    How to successfully install a 110cc fuel tank!
    1.) Your donor will be from Team Associated mini-MGT 110cc fuel tank.
    2.) Next you have to trim the tabs on the side as much as possible so you will be able to place the tank as far away as you can from the throttle linkage.
    3.) Part of the upper deck also needs to be trimmed flushed with the reciever box. The EZ-start has to go to make room.
    4.) After making sure that there's enough room for the throttle linkage, use a playdo to mark your drill holes.
    5.) Use a punch tool to mark your holes.
    6.) Cut 44mm x 23mm off the secondary battery cover.
    7.) The tank should sit perfectly.
    HAVE FUN AND ENJOY THOSE EXTRA RUN TIMES!
    80
    This is interesting, but I posted a while back how to add another fuel tank wihout all the cutting etc. If you look through the posts here under adding an extra fuel tank you'll find it. Also placed a shortcut to the youtube video. But that looks great also.
    Gurley, Alabama
    802
    Could you show more/better pics of that roll cage. And some info like you made/bought, what material used.
    15
    Quote Originally Posted by Mark Ball View Post
    The rollcage is from a Himoto HI905T. Can be ordered from exportpro.biz from the link below. Part numbers (905-002), (905-003), (905-004), (905-005). This rollcage had to be custom fit and fabricated to fit. You need to cut and use your Jato rollbar post as seen on the "Poor man's sandrail" forum pic.
    https://www.google.com/bookmarks/url...0uGTwLrCQ&ct=b
