Results 1 to 10 of 10
    May 2013
    53
    Slash 4x4 and 2.8 Trenchers Wheels/Tires
    Hi guys,
    I just got my Slash 4x4 and I want to change my stock wheels to Trenchers 2.8. Do I need to change anything else like gearing etc? Or I'll be fine with stock car and those monster truck wheels? Any suggestions?
    Canada
    560
    It depends on what battery you'll be running. On 2s, it'll be hard to run with stock gearing so I'd recommend stepping it down to about 11 tooth pinion to handle the power, and you'll need Fans and Heatsinks for both Motor and ESC. On 2s, you really should be fine as long as you aren't bashing with speed pinion. I run 14 tooth pinion, but I have an upgraded motor and I think it's perfect, I just didn't want too much torque that it would wheelie.
    May 2013
    53
    Thanks, I have stock battery which is Traxxas 2cell 4200 25C 7.4V. I just want to keep my car the way it's now, I mean same power etc only with those monster truck tires. It's my first car so I don't really now much about it. Also thinking about battery/charger upgrade soon and also I have no clue what should I look at... I would go with bigger battery.
    Thanks for your help!
    What kind of fans and heatsinks should i get for it? Do u have any links to sites where I can get them?
    May 2013
    53
    Quote Originally Posted by vladsly View Post
    May 2013
    53
    I just ordered fans, heatsinks and I chose Traxxas 3S Lipo 5000mah 25C battery. What gearing will I need for this setup? Like I said before I'll be converting it to monster truck in near future.
    Feb 2013
    27
    it should run about the same speed as it did with the stock tires, if you run an 11 tooth pinion.
    May 2013
    53
    Quote Originally Posted by gowic View Post
    Thanks,
    Is it the right one?
    http://www.rcsuperstore.com/Robinson..._p/rrp1211.htm
    Oct 2012
    Easton, MD
    680
    No, stock pinion is 3mm not 5mm, and .8 mod (Also known as 32p) not 1.0 mod.
    South of St Louis
    6,368
    I'd buy a cheap aluminium fin setup for the velineon off ebay or amazon. That can be a cheapo... Buy one for a 540 motor can.
    Buy a traxxas brand fan for the esc, it fits and plugs right in.
    May 2013
    53
    I'm getting them
