Hello, when I go in reverse at more than a very low speed my tires shake and move a lot! Why is this?
My Slash does the exact same thing. It's just in the design of the steering. It doesn't harm anything.
Slash VXL
Rustler Hobbywing
Summit 1/16 VXL
If it's your rear tire's ,make sure your drive shafts aren't dirty and binding.
Another thing to help wobbling or the "bent axle effect" is balance your tires
Ok, I thought it was just the design, but I'll try that stuff too
Front tires will shake in reverse nothing you can do about it but go SLOWER
Anza Slash & a pile of Parts
Front tires shake in reverse because of the toe. Well, the toe and the play in the steering assembly. If you get bored sometime, try to toe the front tires out a couple degrees and try it again. Most likely, the shaking will stop, or it will at least be very minimal.
the front tires wobble on reverse due to the effects of the ackerman type of steering used on the slash and the Rustler. You can go slower but it will never really go away. I tried and gave up eventually. trying to rid the wobble in reverse will have an effect on forward steering so you have to weigh the benefits/loses with it. In reality, how much driving in reverese do you do.
Maxx3.3/ rusty5700/ slash3800/ slash5700 /4tec3.3
Chuckworks slice a-5 needs engine to run oppisite due to mid engine. Can l fix this with tq radio or switch wires in motor . Please help Slicer
