Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 248
  1. #121
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,656
    I love the green f100 body!
    460, straightpipes, buried throttle, nuff said :D
  2. #122
    Saskatoon Saskatchewan Canada
    365
    I'm honored you added it to my thread.
    Thanks for the compliment on the old Ford.
    Quote Originally Posted by ViperZ View Post
    Oopps wrong Thread... Well sort of, the above action was the cause of the session with Clint Cart yesterday
    You are correct sir.
  3. #123
    May 2013
    Uk
    742
    Omg....the slashers took over the town....I must emigrate and come and bash with you boys.....looked awesome fun....great stuff gents....the cars look wicked!!!!!!!!
  4. #124
    Jul 2013
    Saskatoon, SK. Canada
    2,187
    ^^^ Just wait, we need to plan a big party!!!
  5. #125
    365
    Spent the gift card my wife gave me for my birthday today.
    I'm following ViperZ's lead and bought a set of 1:8 buggy wheels and tires, they are Proline Split six wheels and Proline Badlands tires. Also grabbed the Traxxas 17mm hex adapters, Proline tire glue, tire bands to help mount them, all new wheel bearings, a set of RPM rear bearing carriers (I messed one up at my last outing), the Proline extended body mounts for my F-100 body and some 37.5 weight shock oil.
    Should make for a nice evening of work.
    And I just realized I need the MIP 17mm adaptors.... Part number:10115. Dang; now I wait...
  6. #126
    Jul 2013
    2,187
    Quote Originally Posted by Clint Cart View Post
    Nice additions Clint! Yeah the MIP's require their own 17mm adapters, which I'm not really fond of myself.... Be careful when you are tightening the wheels on them as the design can actually press the wheel hub up against the bearing introducing a side load. That's why the Bearing went on my Rally/GT8... Remember when I said I felt there was a bit of friction in the drive train? this was the problem. The Wheel nuts do not thread onto the hub itself, rather onto the 5mm axle acting like a press to the hub.
    I may try to modify a set of regular hubs where the wheel nut threads on to them. I think it should be easy, just drill and tap the hub for a few set screws and viola! That or drill some small center indents in the axles so the MIP setscrews are really anchored on the axle, and tightening the wheel nut does not press them inward.
    MIP 17mm Hubs
  7. #127
    365
    Thanks for the info and pictures Bing. I was thinking about drilling and tapping two set screws on each on the Traxxas hubs as well, it would be easy to do; the hardest part would be the measuring so I drill the holes on the correct spots, I have a nice Starret calliper to take care of that.
  8. #128
    Jul 2013
    2,187
    Being it's your profession, I figured you would have it cased. Let me know if you decide to do that, cause I have a set I'll bring over for you to be your pigeon... If you like
  9. #129
    Feb 2004
    5,656
    May I ask what colors were used on that old ford body?
  10. #130
    Oct 2012
    Chattanooga TN
    204
    You guys ever loose the set screw and the pins out of the MIPs at the output yoke? I have lost several on my Stampede 4x4 and my sons Summit. Figured out if you put a small piece of heat shrink tubing there it will hold the pins in. No more problems with that. It's real easy to cut off too when you need to access it. $3 fix that lasts a long time. I figured that out after having to replace the female end of the MIP a couple of times.
  11. #131
    Jul 2013
    2,187
    ^^^ Not a bad plan, I have often worried about that being one of the weaker points of the MIP system. That and the open CV. I purchased a set of Stampede boots, that I tried stretching on them. it's not bad, but slightly tore one so I shelved it for now...
  12. #132
    Canton Georgia
    2,149
    I think he is already having one with all of his new parts....
    Let me know how you like the RPM bearing carriers
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  13. #133
    365
    I've had the carriers since day one; they are great; I ended up getting a piece of twine wrapped around the inside of the wheel and it messed up the bearing carrier and wrecked the outside bearing; so I'm changing it.
    Quote Originally Posted by mwe-maxxowner View Post
    The colors are Pactra Lime Ice and Rally Green.
    Quote Originally Posted by Cglennrichardson View Post
    I haven't yet; but I do check them often; it mentioned it in the assembly instructions.
    Thats a good idea, I also use Loctite 242 (medium strength) on all my rotating bits and Loctite 222 (low strength) on all the non spinning bits.
  14. #134
    May 2013
    Uk
    742
    Clint you will love those badlands......they tear up dirt and grass like nothing I've used before....
  15. #135
    Jul 2013
    2,187
    Those 2.8 Badlands are da bomb! I've been eye them up on at Hobby Worlds wall! I'm glad you got them, they needed a good home!
  16. #136
    Oct 2012
    Chattanooga TN
    204
    I use the red Loctite and still toss those pins out until this mod. I actually had a pin come halfway out and saw through the eye of one of the turnbuckles on the Stampede 4x4...
  17. #137
    365
    That's pretty scary, I'll break out the heat shrink.
  18. #138
    365
    So I went ahead and drilled my adaptors.
    I tapped the holes to accept 4mm set screws, there are two on each adaptor so they can seat against the flat spots on either side of my MIP axels, it went well; I'll be installing and testing them tomorrow.
  19. #139
    Canton Georgia
    2,149
    Looks good!
  20. #140
    Jul 2013
    2,187
    Okay, Me next Clint, I'm dropping off my STRC's for you
  21. #141
    May 2013
    Uk
    742
    Great job Clint nice use of drill and tap skills....
  22. #142
    Oct 2013
    218
    Cool driving pics you got here!, must say i like your vw bug body
    Its looks like you only need stainless screw set to your truck then you have all the upgrade
  23. #143
    Jul 2013
    2,187
    Quote Originally Posted by Ray87 View Post
    Agreed! Nice job Clint
    If only I had a drill press, I have the tap, I would do it myself
  24. #144
    365
    Thanks all. Bing; don't you worry, if these work out; you're next.
    Well morning one of R&D is in the bag. The hex's worked flawlessly! I'm very happy with it so far.
    The Ford body on the other hand; not so much, for its first time out it took a beating an the box is all split and cracked.
    I'll be breaking out the Shoe Goo and drywall fiber tape soon.
  25. #145
    365
  26. #146
    May 2013
    Uk
    742
    Wow Clint that's some major carnage to your beautiful ford.....did you go to a destruction derby?... Lol.....what did you think of the badlands?....it's my fav tires atm.....how was the temps with the overtray on....brill testing and report....keep it up my good man
  27. #147
    Jul 2013
    2,187
    Clint, that thing looks beautiful! Go Riders!!
    That's crazy how banged up and shredded that got after one session
    Here is your next project then...
    A Proline C10 just like you were wanting. It is said to be for the Revo, but from what else I have read is it can be made to fi the Slash 4x4
    Okay, deal, I want the custom made hubs over these MIP ones
  28. #148
    365
    Quote Originally Posted by simon32man View Post
    I wasn't all that hard on it, I beat on the Bug bodies far more than what I dished out today. I think it's just all the right angles on the body.
    I love the badlands! They are my favorite tire for the moment as well.
    I didn't check the temps this time out.
  29. #149
    365
    It's a deal.
  30. #150
    Jul 2013
    2,187
    They will be so much more solid than the MIP's...
    And I get to use the Red aluminum again!
  31. #151
    Aug 2013
    115
    Nice truck!, How do those proline adjustable body mounts hold up to bashing?
  32. #152
    Oct 2012
    Chattanooga TN
    204
    Never mind what I said. My son and I went out today and lost another pin right at the start! What is the secret to keeping these things in? It made a hole right through the heat shrink and came out! I use red thread lock and the heat shrink tubing on the outside and just keep losing them.
    I am not at all happy with these MIPs
  33. #153
    Mar 2013
    Saskatoon, SK
    69
    People's experience with the MIPS sure vary. One of our trucks used the blue gel that came with the cvds, the other is using red thread lock. After about 10 2s packs through each there has been no issue. And I'm regularly checking.
  34. #154
    Jul 2013
    2,187
    Man I hope I don't start seeing this type of problems with my MIP's, if so they'll be super glued
  35. #155
    365
    I made sure that the threads were clean before I put the loctite on (cleaned with brake cleaner) and I made sure that the set screw was tightened against the flat spot on the pin.
    I'm going to check mine before I go out again.
  36. #156
    365
    Quote Originally Posted by SASKCHAUCH View Post
    Just got them; so far so good. I like the thread on caps over the body pins.
  37. #157
    Oct 2012
    Chattanooga TN
    204
    Come to find out the pin didn't come out, it broke on both sides of the shaft. It was still in place with the screw holding in the middle but both ends came out.
  38. #158
    365
    Let a good friend of mine tear around the street with the Slash today; he ran it into his brand new car! The Bug was so funny looking I had to share it.
    Both cars are just fine; no damage.
  39. #159
    Jul 2013
    Virginia
    53
    Haha! Love the squished bug. Nice build!
    1/16 Slash, Slash 4x4 vxl, Trail Trekker
  40. #160
    Jul 2013
    2,187
    very nice
