Preferably waterproof with metal gears and won't blow the budget (about the price of the stock ones)
What model E-Maxx do you have? 3905/03 came with dual 2056 servos, 3908 came with dual 2075 servos. I'm guessing since you said "ones" you don't have a 3906. Knowing what you have would help to get a better idea of the price of stock ones.
Yep it's a 3903
Okay thanks if I have time I'll do some searching. Its going to be hard to find a digital servo that is waterproof with metal gears for that cheap that is fast enough and will last. You can waterproof a servo pretty easy and also instead of buying two servos you can use one single high torque servo. I'll let you know if I find anything.
I have a hitec waterproof in my crawler but the price is slightly higher than the stock servos. In my opinion, the 2075 traxxas servos do a fine job in the emaxx, as long as both are working correctly and they are aligned proper. A little bird told me savox is looking into a waterproof servo... fingers crossed and penny jar is full. Lol
The best thing about Groundhog Day??? Bill Murray.
I have through 2 servos and it has only been run about 20 times. I should've said, metal gears are the priority over waterproofness.
This is the one I have used.
http://www.amainhobbies.com/product_...FVN0Mgod130A9w
Another one I have used in my maxx is the hitec 645mg, but if using a metal gear servo, I would recommend aluminum servo arms. Not mandatory, but a good idea.
Keep in mind there are other servos that are better than these I've noted, I just haven't used them or they are out of your suggested price range. Plastidip works great on non-wp servos.
Just out of curiosity. You say you keep tearing up servos, is your servo saver set too tight? Just a thought.
No, actually I was thinking the spring on the stock savers are adjustable but I was mistaken.
