    Sep 2009
    3,525
    home-made N-BONE SKID PLATES for and extended chassis with rear wheel steering
    OK so I couldn't LEGALLY say T-Bone, so they are N-Bone skid plates.
    My chassis ran an inch too long and I also needed some protection for the rear servo and steering system. Unlike the stock summit chassis the SummVee has a bulge at the rear, so the standard T-Bone would not fit. So creative thinking (and some blantant copying . . . . err . . . . . "borrowing") I am making my own "N-BONE" skid plates.
    chassis shot
    N-BONE initial card board mock up and measurements
    A-Arm skids
    fitment
    front servo protection
    rear servo protection
    add some plexiglass, a "heat gun", rite dye, drill and screws and I should be in business
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    muscoda, wi
    1,245
    NO SWEAT. looks like a great idea to make your own. hope it turns out well.
    Riverton Utah
    5,584
    Wow, looks nice, I hope it works out good for ya!
    Is owning 27 RC's too many? No way!
    Half moon building out back
    730
    Noir; make sure and let us know how the heat gun works on the plexiglass as I was wondering the same thing with my extended chassis only not sure how a heat gun would work on Lexan. So might have to change my plans and go with plexiglass.
    Endeavoring to persevere !
    321
    Ive been making body panels for years with a heat gun and that plexi. It works great, just watch your heat or you will boil it and put bubbles in the finish.
    Sep 2009
    3,525
    heat gun works fine. plexiglass is supposed to melt near 320 degrees, but this plexiglass is nearly a 1/4 inch thick. So I set it at 720 and took my time. Less than 10 minutes to heat up, bend and cool down.
    730
    Looks great Noir and should work well. Only one question; did you just use a straight edge on your lines to bend the PG after heating it up? My heat gun only has a high and low no temp settings so guess experimentation will be required on my part.
    Approximately how much working time did you have after heating it up before it cooled back down?
    One more LOL; been contemplating taking the drive shaft skid plate off when I get eds skid plate done, as to me with the big skid plate covering it up why would it be required. Also would make it a lot easier for maintenance.
    Stand offs what are you using, T-bones?
    Oh well went from one question to 3 lol.
    Sep 2009
    3,525
    I used a sharpy to make the lines , then I sandwiched the glass between to wooden blocks on each side with the sharpie line , then ran the heat gun across the line for about 2 minutes. Recommended tem is 320, I was impatient and used 720 (this plastic is around a 1/4 inch thick) . Worked. once the plastic is soft you can bend it to your desired angle. At 720 I had approximatly 2.5 - 3 minutes to perfect the angle before it started to harden again.
    The (stock) drive shaft skid plate effectively keeps out the dirt, pebbles, and debris for it is form fitting.
    No stand offs - its flat against the chassis.
    ____________
    After some rock crawling - It is holding up well, lots of scratches,
    "the plastic screeches as the rocks carves their intials into its underbelly."
    The rear angle is too extreme, big rocks stop it too easily, I think I might redo it with a low angle-ramp design
