Results 1 to 15 of 15
    697
    slayer or nitro slash
    let me know what ya think and a reason why. im debating between the to. thanks
    SLASHING UP WITH MY PEDE
    A long time ago in a galaxy far far away...
    465
    Slayer. Its 4wd Nitro Slash is 2wd
    Drive. Crash. Fix. Repeat.
    697
    is there i specific reason why four is better???
    465
    more control. Better acceleration. better grip.
    SanDiego, CA
    996
    2wd and 4wd are fun, 2wd takes a different skill to drive than 4wd and vice versa, 2wd easier to maintain and work on, 4wd more complicated to work on but in the end wrenching on any car will be easy after you get used to it
    697
    i had many problems with my slayer in the past. i bought it used and i dont think he broke it in right. could that cause problems
    SanDiego, CA
    996
    Yes when you break in the nitro it should be running rich rich rich, lots white smoke if not it could mess with the performance or even toast the engine
    697
    So is that a possible problem I had
    SanDiego, CA
    996
    Well what issues are you having with the truck, I just know when you break in a nitro it should be ran really rich for example excessive white smoke and spitting fuel out of the pipe, then after a few tanks you slowly lean the mixture but you never want to run to lean even after it's broken in completely, every time you drive a nitro there should be a trail of white smoke coming from the pipe
    697
    Well I have gears breaking carb stripping and leaks cant get it tune and it wouldn't stay running glow plug issues
    Oct 2005
    19,414
    Quote Originally Posted by slayer3.3 View Post
    Improper break in can cause premature wear, too much stress on the internals to create a failure down the road...
    Most times though, it's usually poor tuning that causes most of these failures.
    I avoid buying used engines, if buying a used RC, consider the engine toast when pricing... Unless you are able to take it for a test run and using at least 1.2 a tank of fuel to make sure it's OK.
    All Lives Matter
    697
    alright what do u think the nitronaught slash or slayer
    5,613
    Slayer. They both have the same engine, so just break it right, and take your time. That way you won't have issues. I have the Slayer, and I love mine. It's great!
    697
    any maintenance or cautions i need to know about the slayer that i dont???
    5,613
    any maintenance or cautions i need to know about the slayer that i don't???
    Um, could you list what you already know, so we could go from there?
