Results 1 to 2 of 2
    Riverton Utah
    Question EZ Peak Plus Temperature Sensor Settings?
    Hey guys, I just got the temperature sensor for the Traxxas EZ Peak plus. I was wondering what max temperature should I set it at to prevent the battery from getting too hot? The little manual it came with says 43C (110F) for lipos, and 49C (120F) for nimh. It's already saved one of my nimh batteries from over charging. I set it to 6 amps (It's supposed to be 3 amps) because I'm used to charging my lipos at 6 amps. The temperature sensor saved it from probably blowing up or something like that! So, what do you guys think? I'm just wondering if I should change the maximum setting, or if it's fine as is.
    Is owning 27 RC's too many? No way!
    Alma, Michigan
    Fine as is.
