Results 1 to 10 of 10
    May 2013
    Texas
    79
    Receiver Question
    Hey guys, I have a new question for you regarding the stock 5ch receiver in the EMBE. Would it be possible to plug all of the following into it:
    • ESC
    • Single steering servo
    • RPM Sensor
    • Voltage/Temp Sensor
    • Castle CC Blower
    • Castle CC BEC
    I'm thinking NOT since two of the slots are for Ch1 (the original two steering servos). If not, where are there opportunities to combine wires? Maybe the CC Blower and the BEC?
    749
    U can run all of those you just need a servo y harness.
    Alma, Michigan
    12,314
    You can feed the BEC into the open channel 1 slot...
    Channel 1 - BEC
    Channel 1 - Steering servo
    Channel 2 - ESC
    Channel 3 - Blower (or 4 or 5)
    Channel 4 -
    Channel 5 -
    I am not 100% sure where the RPM, voltage, or temp sensors plug into.
    May 2013
    Texas
    79
    Ah! OK. I didn't know if mixing two things on Ch1 would cause any problems, but the BEC isn't sending a signal so I guess it's OK. The y harness is also a great idea. Now I just need to find a cheap iPod Touch.
    Jun 2010
    Miami, Fl
    6,731
    RPM, Voltage, temp have their own slot, they can't be plugged into any other channel.
    Alma, Michigan
    12,314
    Thanks for the picture Fan... I thought so but did not want to give shoddy advice.
    In that case you can stuff the blower and BEC into any open channel after you plug in the items you want control over. The power (+/-) is ran in parallel on receivers. Only the signal wire is different for each channel... except for channel 1 on Traxxas receivers.
    May 2013
    Texas
    79
    For some reason I thought that the voltage and temp sensors used one channel. Maybe because they are sold together.
    Alma, Michigan
    12,314
    According to Fan's post, they do.
    Jun 2013
    Idaho
    150
    Yes they do. They plug into eachother....
    May 2013
    Texas
    79
    Ha! I can't believe I missed that. Even with the picture. Duh. Thanks guys.
