So i have a slight problem.
Once the tires are glued, is there a anything that can remove the glue so that I can re build it up.
I would like to tape the inside to minimize the ballooning effect. (these are the old tires that came glued on)
Or can just plugging the small hole on the wheel rims enough.
Also I have not installed the mashers yet as trying to get the hang of the brushless power (Do they balloon a lot too), before changing to the new wheels.
Live life to the fullest
To unglue them you can do one of two ways. Baking them or by using some act-tone stuff (unsure of the name)
YouTube has lots of vids of the baking method.
Also I cut a slit in my tire then took the foam out in all 4 tires, doesn't ballon. I haven't noticed any thing bad bad about not running foams in stock tires.
God is good.
Bob Smith Industries makes an un-cure ca remover http://www.amainhobbies.com/product_...A-Debonder-1oz
I have a bottle of this and it works good
I have only come here seeking knowledge
