Results 1 to 25 of 25
Thread: Diff problems.
    Ashley, MI
    207
    Diff problems.
    I have a 3903 brushless upgrade with the mm2 running 2s lipos. About every week I am breaking one of the two bearings in the rear diff. What is causing this to happen. It has gotten to he pont that I carry 2 extra diffs so when I'm in the field and it breaks I can replace them. Please post your advice on y this is happening .
    5,613
    Are you running in dirt/sand? If so, the dirt might be getting into the bearing making them go bad really quick.
    Ashley, MI
    207
    Lately 60/20/20 (sand/dirt/gravel)
    5,613
    Hmmm, my bet is all that sand driving is what killed that bearing. Do you have a picture of the bad bearings?
    Ashley, MI
    207
    Not much to take a picture of . All that's usually left is he outside and inside rings
    5,613
    1,945
    If your breaking bearings every week, there is something not fitting correctly/ seals missing, or it's been sprayed with wd40.
    Ashley, MI
    207
    Ok what do u recommend using to grease the bearings
    1,945
    I just use lithium bearing grease from the local cycle shop, Left overs from when i do the bike's bearings.
    The original WD40 is a grease eater and not a lubricant. If you use this then you'll need to clean up the insides and use a grease afterwards.
    Although WD40 is a brand name there is many products under their belt, some lubricants, greases, rust eaters, de-greasers and more.
    nevada, mo
    298
    Will the lithium grease work in the tranny as well?
    1,945
    I forgot to add, the cycle bearing lithium grease is a lot more viscious, than what automotive lithium grease is.
    5,613
    I use either marine grease if I run in wet places, or for dry/on road use I use 3 in 1 oil.
    1,945
    Is it not a bit time consuming changing bearings to run depending on if it's wet or dry conditions.
    5,613
    Ha ha ya, but that's not what I do... What I should have said is I use marine grease in the winter so I can drive in snow, and then I use 3 in 1 oil in the summer when I don't get my cars wet.
    1,945
    After i posted i figured that's what you do, In England we'll be swapping every day.
    1,945
    Is the problem resolved now gunamonkey.
    Brookline, NH
    1,229
    If you want to spend more time playing and less time replacing diffs get some 1/8th scale diffs. and get rid of the problem. The little 6x12 bearings don't hold up very good imo.
    1,945
    I don't put none in there. I just let that run as it is.
    I only grease the bearings and replace diff/shock fluids if it starts to not look right while driving.
    some greases eat plastic and makes it soft and moveable.
    Ashley, MI
    207
    Haven't broke a bearing since but I did destroy a diff last weekend. Wen I opened up the diff the drive gear was cracked,diff cup stripped, and all the Spyder gears destroyed. I was only running 4s. Luckily I had a raplacement diff to through in.
    -EMAXXBRUSHLESS
    Where can I find a 1/8 scale diff to fit in the stock bulkheads. Or a diff bulkhead set, that replaces all of that
    Mar 2001
    Spring valley mn
    1,135
    Quote Originally Posted by Gunamonkey View Post
    -EMAXXBRUSHLESS
    http://www.fastlanemachine.net/prodd...LM17750&cat=15
    http://www.fastlanemachine.net/prodd...LM18750&cat=15
    I have been using the FLM Hybrids for years in both my BB T and Brushless E. Good stuff, haven't had a diff issue since.
    My tranny case is stock :D
    1,945
    It may of been weakened buy the bearing damage from previous runs, Hopefully when this is fixed it should last a lot longer. You can get metal diff carriers from flm I think.
    Ashley, MI
    207
    Not from the bearing damage because i completely replaced the diff after the bearings because I didn't want to have to deal with damage from breaking a bearing.
    1,945
    Do you shim the diffs
    Ashley, MI
    207
    No I don't shim the diffs
    1,945
    I think alot of people have put shims in the diffs and that helped them out. There is a decent write up about it on here somewhere.
