Results 1 to 18 of 18
Thread: More traction
    May 2013
    Sulphur La
    26
    More traction
    What do I need to do for more traction. I have trencher x tires and sand paddles because I bash more than
    Race
    5,613
    What kind of surface are you running on?
    May 2013
    Sulphur La
    26
    Sand, loose dirt and I climb with it
    5,613
    Hmmm, ok. Have you thought about using monster truck tires? There're twice as wide.
    May 2013
    Sulphur La
    26
    The trenchers and paddles bite but its like not all my slayer pros power is getting to the
    Ground like it should
    5,613
    So, you want more power/better power delivery?
    May 2013
    Sulphur La
    26
    More power to the ground. Like when I'm in sand not all 4 tires
    Dont have equal power so it Boggs down a lot and dosnt climb
    very well. I just got into nitro bout 4 months ago so I don't know a
    whole lot
    May 2013
    Attica,IN
    194
    Center diff and upgraded slipper should help out
    T-MAXX 2.5R
    Slayer Pro
    Revo
    Monster Pirate
    May 2013
    Sulphur La
    26
    But if I get the center diff kit won't I half to relocate my break?
    Tucson, AZ
    69
    You will need to buy the rear brake kit. The front disk will stay where it is at and then the rear kit goes on the back side of the trans.
    May 2013
    Sulphur La
    26
    What's y'all's take on diff oil for loose terrain like I'm running?
    5,613
    Since your running in sand, I would almost say just stick in a diff locker spool... But, do you use you Slayer in only sand, or other surfaces too?
    naptown
    591
    +1 on rear diff spool. I have one in my slayer pro, I run on alot of loose surfaces and I love the way mine performs. And If you do some running on the street the slayer pro drifts pretty good with the rear spool in...
    For tires I run 1/8 duratrax lock out tires, have lasted almost two summers for me. And give some great traction in loose dirt, not sure how'd they handle in sand..
    Oct 2005
    19,409
    Paddles great for sand, but stink for other offroad conditions... A set of Trenchers or some decent MT tires like MaxxMashers, Losi Zombies will really stick well in most all offroad and onroad conditions...
    Also, if your rear suspension is too stiff or you have too thick an oil, the rebound speed of your shocks will be too slow to keep the wheels attached to the ground when you are moving. Spinning out easy when applying power on a stright run offroad is a sure sign your suspension might need tuning for your purpose...
    Rule of thumb, more firm the sring the thicker the oil. If your ride is bouncy go to a less firm spring or a thicker oil....
    Also use the preload spacers for ride height adjustment, not to try to firm up the ride, that's just a side affect not the purpose.
    All Lives Matter
    May 2013
    Sulphur La
    26
    What part number is the rear diff locker for the slayer pro?
    May 2013
    Sulphur La
    26
    I use it a lot in sand and loose dirt it's very rare I run it on the street
    5,613
    Here you go. It's TRA5381X. Here's the link.
    http://www.rcplanet.com/Traxxas_Diff...p/tra5381x.htm
    May 2013
    Sulphur La
    26
    Can I use my stock ring gear with it?
