Picked up the sway bar kit 6898 this afternoon and installed it on my Rally. Seems the front has some clearance issues, nothing major, just rubs the front bumper. Anyone else had this same issue?
Thanks,
Will-
I don't have that issue, that is very odd...
Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
I will say this much even with the slight rub on the front bumper, it corners so much better with them on the truck.
It does help a lot, but thats weird, I've never heard of rubbing before.
Are you sure its installed correctly? Or is it the wrong model?
Bought the 6898 kit. That's what it called for. I have the links mounted toward the end of the bar. I could pull them in some, but I worry about the front end have steering issues if the sway bar is to tight.
Show me some pics if you have them, maybe I can see if I fed something up.
Thanks!!!
Can you post pics of it?
No load on the front.
Full compression.
A little blurry, but an over head view under no compression.
Thanks for the assistance.
You could try to shave a little off with a dremel, your rally needs a bath. Or you could also just remount the endlinks farther up the sway bar.
Yes, bath, very true. Too much fun to drive we have no time for bath.
May try moving the links in.
Thanks,
Is it still rubbing?
Yup, going to change the truck over to a slash. So I'll be losing the big Rally Bumper soon. Seems to have not gotten any worse.
Will-
SEMPER FI!!!!
Changing to a rally in disguise, you'll love it I have mine set as a slash, a lot more versatile.
I ran all the tread off the stock tires already. Went and picked up a set of Slash tires. Lov'n the extra ground clearance, plus I love the look of the SC trucks. The **** bodies are pricey!!!
Will-
SEMPER FI!!!!
Glad you like it! I actually have not run mine as a rally. I have every part but the body to run mine as a rally.
Those threaded links are adjustable. You can turn the ends out some to give more clearance, which you should to to make sure you have full suspension travel. Also, you can reverse the ball end mount to put the sway bar link in farther away from the bumper.
AB
I'll try anything once, maybe twice!
