Results 1 to 18 of 18
    Jun 2013
    Missouri
    27
    Sway Bar Kit question
    Picked up the sway bar kit 6898 this afternoon and installed it on my Rally. Seems the front has some clearance issues, nothing major, just rubs the front bumper. Anyone else had this same issue?
    Thanks,
    Will-
    Canton Georgia
    2,149
    I don't have that issue, that is very odd...
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
    Jun 2013
    Missouri
    27
    I will say this much even with the slight rub on the front bumper, it corners so much better with them on the truck.
    Canton Georgia
    2,149
    It does help a lot, but thats weird, I've never heard of rubbing before.
    South of St Louis
    6,368
    Are you sure its installed correctly? Or is it the wrong model?
    Jun 2013
    Missouri
    27
    Bought the 6898 kit. That's what it called for. I have the links mounted toward the end of the bar. I could pull them in some, but I worry about the front end have steering issues if the sway bar is to tight.
    Show me some pics if you have them, maybe I can see if I fed something up.
    Thanks!!!
    Canton Georgia
    2,149
    Can you post pics of it?
    Jun 2013
    Missouri
    27
    No load on the front.
    Full compression.
    A little blurry, but an over head view under no compression.
    Thanks for the assistance.
    Canton Georgia
    2,149
    You could try to shave a little off with a dremel, your rally needs a bath. Or you could also just remount the endlinks farther up the sway bar.
    Jun 2013
    Missouri
    27
    Yes, bath, very true. Too much fun to drive we have no time for bath.
    May try moving the links in.
    Thanks,
    Canton Georgia
    2,149
    Is it still rubbing?
    Jun 2013
    Missouri
    27
    Yup, going to change the truck over to a slash. So I'll be losing the big Rally Bumper soon. Seems to have not gotten any worse.
    Will-
    SEMPER FI!!!!
    Canton Georgia
    2,149
    Changing to a rally in disguise, you'll love it I have mine set as a slash, a lot more versatile.
    Jun 2013
    Missouri
    27
    I ran all the tread off the stock tires already. Went and picked up a set of Slash tires. Lov'n the extra ground clearance, plus I love the look of the SC trucks. The **** bodies are pricey!!!
    Will-
    SEMPER FI!!!!
    Canton Georgia
    2,149
    Glad you like it! I actually have not run mine as a rally. I have every part but the body to run mine as a rally.
    Covina, So Cal
    642
    Those threaded links are adjustable. You can turn the ends out some to give more clearance, which you should to to make sure you have full suspension travel. Also, you can reverse the ball end mount to put the sway bar link in farther away from the bumper.
    AB
    Jun 2013
    Missouri
    27
    Quote Originally Posted by aburg2 View Post
    AB
    I need to mess with it some more, had thought about trying a couple of things you suggested, but to much fun to run, that I hate to have it on the bench to long.
    Will-
    SEMPER FI!!!!
    Canton Georgia
    2,149
    Quote Originally Posted by Ghostrider304 View Post
    Agree on that with you, they are just too much fun...
