Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 167
  1. #81
    Sep 2012
    72
    Congrats! Nice motor.
  2. #82
    Jul 2007
    Rc Room
    1,482
    Good, you kept the roll bar, it makes a great handle. The ERBE could use a handle. Looks nice!
  3. #83
    7,264
    Quote Originally Posted by BL-Bob View Post
    well, its no longer a handle bar I cut it in half so its more of a post but, its great to hold my battery/ESC wire lead.
    I've decided to do what most everyone have done to their ESC fan by covering it with one of those window screen
  4. #84
    El Cajon Ca
    1,805
    I really don't believe you drive that Revo..... It is still way too clean..... I demand a video as proof....
    Once again .... nice job!!
    "enjoy your ride"
    Dennis
  5. #85
    7,264
    Quote Originally Posted by orca44 View Post
    so far I have run it 3 times at my front lawn, don't worry I will have a video posted soon. anyway, I added another chassis support, its really more of a weight balancer with my 4s on one side and the motor on the other side, its just not enough weight to counter balance so, I happen to keep my cut up t-maxx chassis.
    this also give it an even square look
  6. #86
    kansas
    8,677
    an unbalanced truck is no fun....
    when you get a chance would you dye the rockers blue...
    the truck looks lean & mean..... nice work as always......
  7. #87
    7,264
    how is the rockers look like when dye blue? I mean I've dyed my Rally chassis black and that turns out great.
  8. #88
    Sep 2012
    237
    So you can't use twin steering servos with the Teckno kit?
  9. #89
    kansas
    8,677
    the gray looks unfinished.....jm2c...dark blue or a black maybe, dagum the truck just looks..
  10. #90
    7,264
    Quote Originally Posted by vwdaveb View Post
    yes you can run 2 steering servo with the tekno kit, you just have to reconfigure how or where you can mount the receiver box since they have it designed to replace one of the steering servo, but a strong single steering servo like savox or hitec servos will do the trick plus it will lightened up the truck a lot you can do to lightened up the nitro REVO by taking out first gear and lock it on 2nd gear, if your tranny have reverse>>do the FOC, throttle/brake servo, brake mechanism. my truck when fully loaded, it weight at 11.8 lbs
  11. #91
    Jul 2013
    68
    Why do you use long shaft in the front but short shaft in the rear?? I think E REVO has the same length of front and rear shaft, doesn't it?
  12. #92
    7,264
    Quote Originally Posted by JamRevo View Post
    what shafts are we talking about? center shafts or the driveshafts on 4 corners?
  13. #93
    Jul 2007
    Rc Room
    1,482
    Somewhere I got a bunch of rockers dyed several test colors. I'll try and dig them up for a picture tonight.
  14. #94
    7,264
    cool, the more I look at mine, the more I hated them rockers, its not matching to anything. I also still have to buy the beadlock protector
  15. #95
    Sep 2012
    237
    So did you just cut off the other side of the steering linkage? How much torque does that steering servo have? I have a Savox with 125oz torque.
  16. #96
    Sep 2012
    237
    Another question if I may. I'm going to start with the stock tranny for now and use a castle motor. What spur/pinion does anyone recommend to start with so the motor doesn't fry first time out?
  17. #97
    7,264
    believe it or not this is only the 2070 servo, will eventually upgrade later for a better high torque one
    I normally stock up with pinion and spur just incase (pinion 13T, 14T, & 15T / spur 36T, 38T, & 40T)
  18. #98
    Jul 2007
    Rc Room
    1,482
    orange, orange/black, purple and royal blue.
  19. #99
    7,264
    I like how the royal blue turns out, I might pick that color. what dye brand did you use?
  20. #100
    kansas
    8,677
    prob rite dye they do make it in blue, have you dyed before?
    longer it's in the dye the darker, so you can set the color you like...
  21. #101
    7,264
    yeah, I dyed my rally chassis black with rite dye.
  22. #102
    kansas
    8,677
    thought you had...that chassis is nice & black....wow
  23. #103
    7,264
    well, I guess i'd better go to Wal-Mart and pick a blue dye
  24. #104
    7,264
    my truck on a balance pole
  25. #105
    7,264
    OK, I just finished greasing my driveshafts CV joints, I even open up and grease all my bearing carriers, thought that would eliminate the binding but, that didn't help at all. The binding only happens when all wheels on the ground and it gets heavy when the wheels are turn either left or right. I'm stumped right now......what gives?
  26. #106
    Newcastle, Australia
    969
    Somebody needs to tidy up their work space
  27. #107
    7,264
    Quote Originally Posted by JoelRobbo View Post
    I wanted too but its not my belongings, only living with relatives since we lost our home 2 years ago.
  28. #108
    kansas
    8,677
    binding?? what is binding??
  29. #109
    7,264
    it has this braking like feeling when I push the truck and it gets stronger if I turn the wheels to either left or right. pinion and spur are away from each other. it wont do it if all wheels off the ground.
  30. #110
    Aug 2012
    447
    it's been a year since i've visited this forum...congrats humay on ur build...it's nice to see that u still have the passion for it...
    keep up the good work...ur an inspiration...
    i've started working on my projects again...finished the 1/8th GT build...destroyed the tekin esc with 6s in about 10min after the completion of the build...was able to get one speed run at about 80+ mph (i'm thinking...didn't officially clock it)...
    but seeing ur build here...definitely brings a smile to all my woes...
  31. #111
    7,264
    OK I find out what causes the problem, turns our the electrical tape that I roll at the neck area of the diff case start to move and fall in between the drive cup/ diff case. reason why I roll that tape was to give it a good snug fit.
  32. #112
    Australia
    3,338
    Maybe try some heat shrink mate...it will give a good snug fit. Glad you found the problem . BTW your rig looks good .
    Rock n Rolla !
  33. #113
    Sep 2012
    72
    wow... just wow....
  34. #114
    7,264
    Quote Originally Posted by MITCH316 View Post
    thanks mate, I might try and grab some shrink tubing at harbor freight.
    Quote Originally Posted by hfofhf View Post
    wow... just wow....
    so far so good. and by the way, here's what my first thought of locking 2nd gear before I went with XO-1 34T. I believe RC monster the only one that carry them,
    what's great about this one is you can change gear of your choice 34T to 40T just make sure to pair the top gear also
    what sucks about it is that it cost almost $30
    maybe i'll show this to my bro maybe he can mill me one or two
  35. #115
    Norway
    290
    Hey humayrayakongkinaon, where did you get that plastic mesh cover for the fan, and what's it called?
  36. #116
    Sep 2012
    72
    I know your set-up has better balance, but I didn't know the balance is that good. How much does your battery weight?
    I'm leaning to 40T. My motor is hot with 13/40T and stock wheel. I have to run with badlands.
  37. #117
    7,264
    Quote Originally Posted by ignis View Post
    its a window screen, our dog here been tearing up our window screen so I cut a small piece and shape it to fit , but you can get them at home depot, lowes or any hardware store.
    I got the 4s lipo from hobbypartz http://www.hobbypartz.com/77p-sl5000-4s1p-40c-4444.html its always out of stock though.
    then I counter balance it with that piece of aluminum chassis from my old t-maxx surprisingly it balance perfectly.
  38. #118
    Sep 2012
    72
    I'm running 2x2s hard case lipo, which is cheaper but 50 grams heavier than yours.
  39. #119
    7,264
    yeah, I use to run 2x2s and they are hard case so it makes it even heavier.
  40. #120
    Sep 2012
    72
    is rc monster still carrying this item?
