Results 1 to 3 of 3
    Newcastle, Australia
    969
    VXL-3S Flashing Red ESC Light
    Hey guys, my mate just bought a new 3S 5000mah lipo battery and when it is in use the car will only travel about 100ft before the there is no throttle and only steer, the ESC or motor are only luke warm. What could the problem be? Is the ESC thinking its too hot and is going into thermal shutdown? Any help would be great, thanks.
    RC Champion dcfox's Avatar
    SE Texas
    1,206
    Might be a defective battery or charger.
    What battery?
    What charger?
    What amperage are you charging the battery at?
    "Dude,I almost had you"
    R.I.P Paul Walker
    969
    Quote Originally Posted by dcfox View Post
    What battery?
    What charger?
    It's not the charger because it charges his 2S fine and works in the car without a problem, but his Gens Ace 5000mah 40C charges up fine and holds charge without a problem. When you turn the car on, if you straight away calibrate the ESC then the car will run fine most of the time until turned off next.. Has got us quite puzzled
