Results 1 to 13 of 13
    Jul 2011
    Sioux City, Iowa
    186
    Suspension set ups
    I've had my revo 3.3 for two years now. Just put a new motor and sway bar kit in. I am just looking to find more info on anything suspension. Color code of springs, the rocker arm differences. How long the sway bar links should be etc etc. I know I'm not being very specific but if you need more clarification just say so
    SD California
    1,157
    I use a light spring rate and a thick shock oil (55+). Been running that setup for about a year and it works well.
    Jul 2011
    Sioux City, Iowa
    186
    How well is the rebound? No sag?
    SD California
    1,157
    Rebound is slow. It sags a little but when you are moving it works well. Spring rate doesn't determine your ride height, spring length and preload do. It takes the big stuff well. I run on the track with it 90% of the time. I'll take a picture to show the ride height.
    Full travel
    I dropped it from a couple feet and this is where it sat
    Jul 2011
    Sioux City, Iowa
    186
    Sweet body! Stock body? Did you paint it? What rocker arms? And what spot on the A arms are the push rods at?
    12,490
    Quote Originally Posted by 1_handed_bandit_green View Post
    Your manual has good information into the spring and rocker differences as well as the roll center, caster and camber. If you don't have a manual, download it through the Support tab above.
    Jul 2011
    Sioux City, Iowa
    186
    I was trying to get personal information. I know there is info in the manual. And the manual doesn't have specs on aftermarket sway bars which is what I'm trying to understand a lot more.
    SD California
    1,157
    The body is the revo platinum body. The rockers are the p2's, I think they are in the middle holes.
    Jul 2011
    Sioux City, Iowa
    186
    That's what I was thinking about the body. I have the p2 on as well. I've tried 60wt but the sag and rebound I don't like. To have a stiff responsive shock should I go with heavy oil light spring?
    12,490
    The light spring will not overcome the heavy oil and it will sag and not respond the way you want. If you go a heavier oil you'll have to go to a stiffer spring. Too stiff a spring and too light an oil will make the truck real bouncy. The spring holds the weight, the shock dampens the spring action.
    SD California
    1,157
    I use the green and gold springs. So they are right in the middle.
    SD California
    1,157
    If you want a faster rebound try 50wt but I wouldn't go below that.
    Oct 2005
    South Florida
    19,411
    Faster rebound rate requires thinner oil and/OR a more firm a shock spring depending on the situation. Too fast a rebound rate will make the truck bouncy, too slow a rebound rate will make it easier to lose traction when you apply power. Or you apply power and it seems to want to spin out of a turn way too easily..
    All Lives Matter
