Page 17 of 22 FirstFirst ... 71516171819 ... LastLast
Results 641 to 680 of 879
  1. #641
    May 2013
    Uk
    742
    I have another STC body planned for this operation, however I'm thinking now I should get a buggy body or maybe something like an E-Revo.... just so the tracks throw snow outside of the body.
    I got 2 JConcepts LCG Overtrays for this snow operation, however I'm thinking a specific snowbuggy looking machine may be fun
    sounds like a great plan viperz.....and I know a man of your calibre can pull it off with ease......exciting stuff
  2. #642
    Canton Georgia
    2,149
    Is it just me or does it lift the truck higher off the ground?
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  3. #643
    Oct 2013
    8
    Thanks. Wow, this truck flies! I love as it cartwheels after hitting some bumps at full throttle, and lands on the wheels and off it goes again. A few follow up questions:
    1) what fan do you recommend, and is it easy to install?
    2) What temp is too hot? I thought if I wasn't on full throttle the whole time, I'd be fine... The motor did get pretty hot with the 11.1. It probably isn't help that it was insulated with lots of dry brush that found its way in to the chassis.
    3) There is a small red wire with a small red rectangular end tha comes out of the motor, and tucks in next to the ESC. What is that for? What plugs into that?
    4) any good posts you recommend for me to learn about pinions? Which one comes on the Ultimate, and do I really want to mess around with changing it out?
  4. #644
    Jul 2013
    Saskatoon, SK. Canada
    2,187
    Thanks Simon Duder
    Quote Originally Posted by sean1214 View Post
    Nope, your eyes are good, they truck is higher for 2 reasons. 1) the center of the axle is higher on the Cat Track than a 17mm tire. 2) I've cracked down on the coilovers to get maximum height.
    Quote Originally Posted by Bmorrison View Post
    I used an Integy single fan heat sink n the motor, and the stock Traxxas fan on the ESC
    They typically say about 175F max
    That's a power take off for a motor fan or ESC fan. You will need to make a Y splitter to connect both.
    Not off hand, but read your manual. Typically the lower the pinion the more torque, same for the spur Yes!! you should mess around in there as that is part of knowing what RC is all about. Stock gearing is 13/54
  5. #645
    Jul 2013
    2,187
    Snowed a little last night... Not enough to really test the snow tracks, but enough that it makes me think I should swap out to snow tires on the full size cars, and get some others ready for winter storage, full size and RC...
  6. #646
    Canton Georgia
    2,149
    Quote Originally Posted by ViperZ View Post
    Bye bye M3, hello Slash 4x4!
  7. #647
    Jul 2013
    2,187
    More like "Good night M, XO-1, Rally/GT8...." "Hello winter tracked Ultimate and SUVs!!"
    Took some time and installed the JConcepts over tray. I thought one of these may not be a bad idea, for the winter action, but snow really spin drifts, and it's probably going to get packed in there anyway.
    Oh well, because the tray was designed for a standard LCG chassis, I had to make modifications to the Rx area to make it fit. I also cut the tray longer than normal so accommodate this custom fitment. The Photos below should explain it all.
    JConcepts LCG over tray
    Needed to be fitted taller than normal due the placement of my Rx box
    Even then it was not enough so I had to make some mods
    A heat gun to the nose of the tray then pulled over the chassis and Rx box worked well
    Velcro'ed in place ready to roll!
  8. #648
    Canton Georgia
    2,149
    Are you going to run just the overtray?
  9. #649
    Oct 2012
    Chattanooga TN
    204
    Looks interesting. Can't wait to see some video footage in action.
  10. #650
    Michigan
    7,877
    I really like your style ViperZ, your an all or nothing kinda guy.
    Is there really any other way to be?
  11. #651
    Jul 2013
    2,187
    No, it needs a body, otherwise it's just an RC chassis, no class in that
    Quote Originally Posted by Cglennrichardson View Post
    I'm waiting for a snow day to get it captures, but may have to just get one of it rolling around on grass and dirt.
    Ha, Ha, Thanks Billy... I've been told that often it seems
  12. #652
    Canton Georgia
    2,149
    Okay, so one thing I know will happen is snow sticking to the body and add 10 pounds to the truck. Unless you want to lower it....
  13. #653
    Aug 2013
    115
    Those tracks are siiiick. Nice work
  14. #654
    Oct 2013
    21
    Are u buying all these bodies for retail or u getting hooked up?
  15. #655
    Jul 2013
    2,187
    How would lowering it help? Maybe I need to add a 1515-2200kv with a 6s?
    Quote Originally Posted by SASKCHAUCH View Post
    Thanks!
    Quote Originally Posted by yeezus View Post
    If I think I get what your asking, yes, I'm paying for these bodies myself
  16. #656
    Michigan
    7,877
    Keep us well updated ViperZ, I'm eye balling a set in blue but will patiently wait a review.
    I'm thinking about trying them in my 2650 setup.
    Then again a snow track Rally would look awesome as well.
  17. #657
    Canton Georgia
    2,149
    How would lowering it help? Maybe I need to add a 1515-2200kv with a 6s? -
    Nnnooo, the weight of the snow would lower it.....
  18. #658
    May 2013
    Uk
    742
    you deffo have the wrong user name?....you should be the iceman...Lol.....as your soooooooo cool with your building ability and ideas......looking good bing......
  19. #659
    Oct 2013
    Maryland, USA
    171
    Viperz your picture amazing. Share your shutter speed i have a canon 6D but most of all your picture beautiful.
  20. #660
    Jul 2013
    2,187
    For sure, we should be getting some snow soon.... I think a Snow Rally would be awesome! I put the Rally body and the Ford Focus body on just for a look see
    Riiight...
    Quote Originally Posted by simon32man View Post
    Ha, maybe so, Thanks Simon!
    Quote Originally Posted by raved007 View Post
    Thanks!, The shutter speed varies from shot to shot. Most times I use the camera in Aperture Priority, in that I select the aperture and the camera chooses the shutter speed based on available light. During action shots I will use Shutter Priority, and let the camera select the aperture. The speed I select depends on the effect I'm looking for. For blurred backgrounds use a slower shutter speed, <1/100 and a steady hand. For frozen motion shots use>1/400. Hope that helps!
  21. #661
    SLC, Utah
    3,432
    What a terrific Thread u got there bro.
    As for the chassis dying, U have to boil it. So keepin it on the stove top, and keeping it boiling for over 20 minutes at least. I keep mine in for ever.
    Amazing work, and really enjoyed it... Only got through page 8 this time, and wil have to continue reading later its so extensive Excellent stuff
    Build, Bash, Clean, Repair, Repeat..
  22. #662
    Nov 2011
    North Central OH
    1,050
    You are very entertaining to follow along with Viper A man with no limits LOL
    Thanks for the 'no boundary' builds............I am enjoying them and a compliment on your paint work too!
  23. #663
    Oct 2013
    44
    I finally made it through the whole thread!!! Bravo. Also made it through the Rally thread. Bravo, again!! Good stuff. Cheers.
  24. #664
    Jul 2013
    2,187
    Quote Originally Posted by AbSoLooT1 View Post
    Thanks AbSoLooT1! I dyed my Rally chassis by letting it soak for about 1 hour in boiled water, it's holding up so far, but it's mainly on road.
    Quote Originally Posted by kwitty View Post
    Thanks for your kind words Kwitty! I have a tall order to live up to now
    Quote Originally Posted by RearWindow View Post
    Thanks for taking the time to read and comment, it very much appreciated Rearwindow!
    I would also like to take this time to thank everyone that has read and commented on my thread. All, your help, comments, guidance and suggestions makes it so much more, part of the hobby that really inspires a person. Thanks to you all!!
  25. #665
    May 2013
    Uk
    742
    I would also like to take this time to thank everyone that has read and commented on my thread. All, your help, comments, guidance and suggestions makes it so much more, part of the hobby that really inspires a person. Thanks to you all!! [/QUOTE]
    sounds like your saying fairwell?......
  26. #666
    Nashville, TN
    2,078
    Post #666! Mua ha ha ha!!
  27. #667
    Jul 2013
    2,187
    Nope, not at all, just wanted to take the time to say Thanks to everyone for making this thread what it is
    Quote Originally Posted by Jws1982 View Post
    Well Played....
  28. #668
    Jun 2009
    Indianapolis, IN (castleton area)
    402
    ....ugh, i do believe that would be YOU, bud!
  29. #669
    Jul 2013
    2,187
    Quote Originally Posted by Godspeed View Post
    Ha, Ha, Thank You!
  30. #670
    Canton Georgia
    2,149
    You are very welcome! Where did you get that cool smiley from?
  31. #671
    San Jose, Costa Rica
    704
    Excellent build!!! Subscribed...
    Just a little question:
    How is holding the HR Motor Mount?
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  32. #672
    Jul 2013
    2,187
    Quote Originally Posted by DBG View Post
    Thanks! Do you mean how well is the HR mount holding out? Very well! I have one in my Rally as well, and they are really nice motor mounts.
  33. #673
    704
    Ok, Thanks...Is for my future LCG 4x4 slash...For be sure, is this one, right?:
    http://www.ebay.com/itm/131024853478
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  34. #674
    Jul 2013
    2,187
    Yes, that's the right one and the same seller I bought mine from.
  35. #675
    704
    Ok, thanks.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  36. #676
    Oct 2013
    Maryland, USA
    171
    Hi ViperZ how did you made the tiger stripe on the side?
    Excellent!!
    Finished the Silverado body, It turned out better than I had expected! It was an experimentation in different paints I had never used before, and different techniques. It's really had to capture the overall effect in pictures as I had to underexpose the images just to capture its essense.. It was a lot of BLING, for the camera!
    • First was the Spaz Stix Chrome Grill and side moldings.
    • Then the Lame Flake in the back section followed with black backer
    • Pearl white base for the main body color
    • Tiger stripe masking on the side
    • Fluorescent Green paint followed with white backer paint
    • Lame Flake on blue section followed with metallic blue & then silver backer
    • Fluorescent Orange on the Tiger stripe followed with white backer
    • Spaz Stik Chrome Stripe followed with Aluminum silver paint
    • Decals, and that was my morning
  37. #677
    May 2013
    Uk
    742
    ^......page 11....post 423 will give you this info..
  38. #678
    May 2013
    Uk
    742
    [QUOTE=ViperZ;5595944]Nope, not at all, just wanted to take the time to say Thanks to everyone for making this thread what it is
    Phewwwww........for momentary lapse of reason I thought it was....Lol.....hmmmmmm.......that's a familiar song....Lol..
  39. #679
    Jul 2013
    2,187
    Way to look out for others while the bar keep is away, Simon!
    A great album!
    Okay seeing as I was taking some pictures, I had to take a proper picture of the JConcepts cover.
  40. #680
    Canton Georgia
    2,149
    Looks good! Only if it wasn't so hot in California....
