Results 1 to 30 of 30
    30
    steel main diff bevel gear set VXS9282
    Still learning. braking a lot of stuff are these any good or stay with with stock. Hot Racing Traxxas 1/16 E Revo Summit steel main diff bevel gear set VXS9282. Also stock cases or alum. ones. Wife gave up on me
    Spending $$$
    Alma, Michigan
    12,314
    The jury is still out on the HR diffs. Too new to tell.
    A proven but not perfect solution is aluminum bulks, shims, and new diff parts.
    30
    ?? Aluminum bulks with stock parts or ? Can you give me some brands Thanks for any help
    Alma, Michigan
    12,314
    Yes, new stock parts with any aluminum bulk. They all seem to function about the same... no complaints from any user on any brand.
    Sep 2012
    cold lake,AB
    65
    i have them and im still testing trying to get the mesh right cuz it sounds horrible at the moment
    405
    I just got one of the HR diffs off ebay cheap. Can I run it in the rear with the stock diff in the front? I'm assuming the ratio is the same but wanted to make sure.
    Feb 2002
    9,398
    yes it is fine to run it like that......
    actually the way i am setting mine up right now.....
    as for sounding like noise, the new hr diff is going to be crazy loud, and not sound like stock due to the contact patch the new gears have
    i have already setup my new rear diff, and i have 6 shimes in there, i am also running an hr bulkhead as well -- i am also running racer's edge diff lock putty
    405
    Hi, how do you shim this, is it just the ring gear or do you shim the pinion too?
    Feb 2002
    9,398
    Quote Originally Posted by robl45 View Post
    I just did the ring gear on the ring side..... some people also do the pinion gear
    I found that on mine, there was no play in the pinion, and my 6 shims eliminated all the side to side play on my ring
    405
    okay thanks, it comes with no instructions and I wasn't sure if this one was different because of the bevel. I'll fit it together and see what it looks like and figure out how to shim it.
    sure wish they offered the ring and pinion separate on this.
    Mar 2001
    Spring valley mn
    1,135
    Hopefully they wont be needed! Looking forward to hearing how they work out for you.
    My tranny case is stock :D
    Feb 2002
    9,398
    the gears are a set, you can't use the pinion from a stock set with the gear from the bevel gear set
    405
    Of course not, but the way the hr is setup, they could still pinion and ring gear separate from the housing so you don't have to replace the whole thing.
    405
    Well it's in, I used 6 Shims, 5 probably would be okay, but it spins nicely with 6. Anyway, the diff isn't working well, one tire I can spin back and forth,and other tire goes opposite direction Like normal, but other side, I can turn wheel one way, but it's solid when trying to turn other way. I don't think I tightened the diff too much as I assume you crank it down as there are no seals to keep the oil in.
    Aug 2007
    So Cal
    21,511
    6 shims?!?!?!? Sorry just no way I can buy that is right IMO 3 shims is a lot 6 shims makes me think something is drastically wrong.
    No seals? That definitely is not right for a diff that uses diff fluid. Only diffs with no seals are diffs like in the 2wd Traxxas vehicles that are meant to use grease not diff fluid like the 1/16th scale vehicles do
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    405
    The hr diff has more play, needs more shims. It uses the little seals where the outdrives go, nothing else.
    Nov 2011
    277
    Yeah there are guys running 6-8 shims over on URC.
    I agree with Dad, thats not "shimming" anymore, and if it needs that many, the product is defective and I will not be using it.
    405
    Quote Originally Posted by igglesfan View Post
    To each their own, but this diff is solid. It's super smooth, no worries about making sure things are straight when putting it together and it sounds cool when it does it's whirring from the bevels.
    Aug 2007
    So Cal
    21,511
    Yet you are still posting that you have the clicking noise and say the diff is not working right?
    BlindMan Racing
    SPC Lipo Power
    405
    I do have a clicking but I think I got it now, I changed the internal gears and I think that should do it. Either way it wasn't the ring and pinion.
    But regardless, this diff spins way smoother than the stock one ever did.
    405
    Well the noise is finally gone, internal gears were bad, and this diff is still awesome. I don't know that its 33 dollars awesome which seems to be the going price, but I paid just under 23 bucks and for that price, Its great.
    Mar 2001
    Spring valley mn
    1,135
    Glad you got it sorted out! Hope it lasts, if it does it will very much be worth the 33 dollars.
    405
    Quote Originally Posted by buzzsaw 46 View Post
    Yes, I suppose it would be worth the money as they are nicely crafted pieces for someone that knows how to drive correctly. My son will probably trash it within a month or so but its definately a nice piece. I've dealt with many aftermarket products in 25+ years and most end up being a bit of a hassle, but this drops right in, fit is great, solid piece of engineering, no guessing if the ends are straight or anything.
    Mar 2001
    Spring valley mn
    1,135
    I have bought many after market "upgrades" that didn't live up to the manufacturers performance claims also. I'm very much looking forward to your feedback on this diff set. I know you had a lot of problems with the stock diff so if this one holds up to your Sons heavy trigger finger it should be bomb proof for most of us.
    Jun 2003
    Estes Park, CO
    935
    Also just so you all know running a hr and a stock diff together is stressing your driveline. The ratios are slightly different as the HR diffs have less teeth (so they could beef up the existing teeth) on the ring and pinion. The ratio is close but not exact.
    Sent from my iPhone using Tapatalk 2
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
    405
    This seems discontinued, did anyone make another diff like this? Still going in my sons truck and its much better than replacing diffs every 3 weeks. I want to get one of these trucks for my daughter, but without this diff, its probably a waste of time as daddy has more to do with his life than replace differentials.
    Alma, Michigan
    12,314
    There are more than a few threads stating that the HR diff was no stronger than the stock diff... and the HR diff was more expensive. That could be why it is discontinued... if it is.
    Running a shimmed diff, on 2S voltage, with an adjustable ESC... to reduce punch and only allow the ESC/motor ease into the power... I was able to keep from stripping out anything diff-wise for over 2 years of running. I did, however, have to rebuild a few times due to the fluid leaking out.
    405
    Quote Originally Posted by JimmyNeutron View Post
    This is for a 5-6 year old and potentially a 4 year old, only so much I'm putting into it. All I can tell you is that my son has been beating the crap out of this thing and the diff is still intact and I shimmed the old ones over and over and still they stripped. My wife tried driving it and she is much worse than my 5 year old and still its intact. He slams it full power into things, still the diff is intact. Me like this diff.
    Mar 2015
    14
    Off topic a little but it is literally driving me insane, I can't fix this wobble in the rear diff, I have tried everything (completely new everything, shimming, adjusting the screws on diff ETC). No matter what I do it has a rough spot in the same spot every time. I wouldn't care so much if it didn't destroy my rear diff. It starts out slow by shaving little by little of that one little spot; and it's really no big deal if I clean it after every run but the little pieces tear up the rest of the diff pretty quickly. I have searched and searched MANY forums about this issue and I have seen others with this same problem but no fix. So if anyone has any ideas or fixes please help me, my wallet will thank you.
    Some other info, I only run 2s, stock esc and motor, completely metal drive shafts, 10k in rear 30k front no center diff, stock bulkheads and diffs.
    Mar 2015
    14
    Quote Originally Posted by Vallone1990 View Post
    Well if anyone cares I managed to get it pretty smooth by jamming a flat head in between the ring and pinion where the rough spot started and pried them apart a little.
