    Jul 2011
    Sioux City, Iowa
    186
    Should I drain my batteries before charge?
    Is there a device I have to use to drain them? Or just leave the battery in the car with it on until it drains?
    Alma, Michigan
    12,314
    You do not want to completely drain your NiMh every run. You want to stop using it when the RC slows significantly and then recharge after it cools. Completely draining and recharging them every time will kill the life span dramatically.
    Jul 2011
    Sioux City, Iowa
    186
    Alrighty. Thanks!
    Jul 2011
    Sioux City, Iowa
    186
    Is there a certain voltage I should not let it get to?
    1,335
    What kind of charger you using. With mine after a run i will usually run a discharge / charge cycle. I have my charger programmed to bring them down to .9 or 1 volt per cell (cannot remember). I find this way i get accurate info on the state of my batteries by the final mah reading. Its not necessary to do it i just find this system works well for me. I have actually been able to save a few batteries this way as i seen a few times where the charge was very low so i set the charger to 1 amp and cycle charged a few times until the battery came back to full charge
    Jul 2011
    Sioux City, Iowa
    186
    I've just got the Traxxas charger. I only have the rechargeable battery for receivers and the ez start.
    Dec 2004
    PA
    4,079
    Quote Originally Posted by 1_handed_bandit_green View Post
    When you notice the RC vehicle slowing noticeably, stop.
