Temp/Voltage Sensor on Rustler VXL
just go my temp/voltage sensor today and i was wondering how to install it on a rustler vxl
The temp sensor(if you want to monitor motor temp) has a separate mount that you use to zip tie the sensor to it. Sold separately. Mount that to the end of the motor. The voltage part of it also has an adapter, sold separately, that goes between the battery and ESC. If you don't have the Traxxas plug then you can do what I did and get a female servo connector then solder the open end to the ESC side of the Pos power cable. Works like a charm for me so far.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
