Results 1 to 20 of 20
    wales uk
    65
    Fitting a 5" rudder what is the best way
    Hi want to fit a new 5" rudder onto my spartan but looked at all the options on this site but still can't pick the best way can you guys that have done this mod send me some pics on which way you fitted it and how it runs after you have done this mod thanks.
    Jun 2013
    Corona,CA
    111
    Here is a pic of mine. It is by far the best upgrade that I added. It eliminated my chine walk.
    Apr 2013
    368
    Thats how I did mine.. I drilled out the hole with a step up drill bit. I did put my holes a little crooked though
    Im unsure of how it will affect it. Its only a little off.
    wales uk
    65
    http://s1334.photobucket.com/user/Tr...tml?sort=3&o=0 thanks carnes99 I done the same as you did you have any trouble with the boat iv now got it leans to the right at high speed http://s1334.photobucket.com/user/Tr...tml?sort=3&o=1 any idea how to sort it http://s1334.photobucket.com/user/Tr...tml?sort=3&o=2
    Apr 2013
    368
    Sounds like you have torque roll. Move your strut position. Google spartan torque roll
    RC Qualifier PowerDemon's Avatar
    Jun 2011
    Fredericksburg, VA
    403
    Should the strut be angled up or down?
    E-Maxx and Spartan
    Jun 2013
    Corona,CA
    111
    Quote Originally Posted by traxxas mad 76 View Post
    I had the same thing happen, but thought it was my new prop that was installed at the same time. I sharpened my prop and slightly adjusted my trim tabs, and it now runs straight as an arrow. I never touched my strut angle.
    wales uk
    65
    Hi carnes99 it's goes in a straight line but the boat lifts up on the left hand side and lowers the right into the water looks like the boat is leaning over only at high speed
    Oct 2011
    naptown
    591
    I've been having the same issue with mine. Gonna do some adjustments on my inner trim tabs and try lifting my strut up some. and also Sharpen my prop some more.
    Did read a good article yesterday that helped my understand rc boating alot more. I'll do some looking see if I can find it again.
    MERV SV3/5700
    Slash MMP/2400
    Slayer Pro
    Spartan
    Jun 2013
    Corona,CA
    111
    Yeah that's exactly what mine was doing. Here's a thread that I had started about it.
    http://traxxas.com/forums/showthread...05-Torque-roll
    Oct 2011
    naptown
    591
    http://www.modelpowerboat.com/conten...-hull-attitude
    Here's a article I found the other day, has some pretty good info in there. Well I found it useful as this is my first RC boat.
    MERV SV3/5700
    Slash MMP/2400
    Slayer Pro
    Spartan
    Sep 2010
    29
    how do you know where to place 5" rudder? does it come with instructioins? I may have to buy it from kinetic racing because OSE is always out of stock on there stock dual water pick up. is it centered or appears towards starboard side but how much?
    Jun 2013
    Corona,CA
    111
    Quote Originally Posted by JKERR View Post
    It's just about the same position as stock, in port/starboard terms. It does sit aft a little more.
    Sep 2010
    29
    ok carnes so you use same holes and ream them out a bit for new rudder? Would everyone recommend going for a 5 inch rudder with dual water pickup as opposed to the stock one at OSE that has dual pickup? I was hoping for stock dual pickup to avoid the work of installing a whole new 5 " but it the benefits are so goood maybe I will? especially when OSE is always out of stock.....of everything!
    Jun 2013
    Corona,CA
    111
    You have to make 4 new holes. If you look at my first pic up top, you can see where the original rudder holes are on the right. I don't know if this is better than the stock dual rudder, but I like it. Plus it's half the price than the one from OSE.
    Jun 2013
    Maryland
    557
    Quote Originally Posted by BomberSTi View Post
    GREAT article. That's what I wish was in the manual. That should be a sticky.
    wales uk
    65
    Rudder all done and torque roll and chine walk gone rudder removed the chine walk and for the torque roll i put a shime of 2.8mm into bracket and that removed the torque roll small photo in link if any body needs it http://s1334.photobucket.com/user/Tr...D=1&sort=1&o=0
    Mount Real, Canada
    628
    Carnes99
    Where did you got your rudder? Is it from Rcbitz?
    Sharing is the best thing to do on EARTH legally.
    Jun 2011
    Fredericksburg, VA
    403
    You can get the rudder from http://www.kintecracing.com
    E-Maxx and Spartan
    wales uk
    65
    Hi edgemoulic I got it from ebay if you need any info on how to fit pm me and il do my best to help it was around 20 and very easy to fit it was the torque roll was the problem but it was a easy fix in the end
