Page 2 of 19 FirstFirst 123412 ... LastLast
Results 41 to 80 of 732
  1. #41
    May 2013
    Uk
    742
    Quote Originally Posted by ViperZ View Post
    I seen these Hot Racing shocks and decided to give them a try on the Rally... If anything I liked the look of them. They seem to have a high spring rate so I hope they allow me to get a lower ride height equal to the GTRs on the Ultimate.
    If not I'll swap them out with the GTR's or try something else. We installed the Losi Ten SCTE dampers on my friend's Slash last night. They look like a nice shock for the price as well!
    im loving the look of those they look awesome...I want...I want...Lol
  2. #42
    Jul 2013
    Saskatoon, SK. Canada
    2,187
    Quote Originally Posted by simon32man View Post
    Lol clearly this is an addictive disease when you have those most excellent Power Strokes I want a set if those too!!
    Thanks man!
  3. #43
    May 2013
    Uk
    742
    Thanks man!
    Lol.....true....it's the shininess and colours that do it for me...
  4. #44
    Jul 2013
    2,187
    Me too! I'm such a sucker for colors and shininess
  5. #45
    Jul 2013
    2,187
    The roller arrived today as well as some add on parts. It looks to be in good order! The body has seen some action, however the chassis and components looks nearly new.
    The STRC Motor plate was a bonus, it was not mentioned to me
    I like the aluminum STRC servo cranks
    Some of the hop-up parts.. She is going to be a mix of color
  6. #46
    Jul 2013
    Honey Brook, PA
    154
    just keep the pics coming and check your PM
  7. #47
    May 2013
    37
    Wanta part with those tires/rim that came on the roller?
  8. #48
    Canton Georgia
    2,149
    The only problem I see is that their is no flexible point in the shocks, which might lead to damage, hopefully not though, looks can be deceiving...
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  9. #49
    Jul 2013
    2,187
    Quote Originally Posted by BEvans454 View Post
    Okay, will do!
    Quote Originally Posted by kz9 View Post
    Thanks for the interest. I think I'll just hang on to them, unless that is you really need and want them...
    Quote Originally Posted by sean1214 View Post
    I was thinking this, but over all I'll take the stiffer response. The unit will be mainly a road rally car leaving the hard core bashing to the Ultimate. Even then the Ultimate is following closely behind as I'm installing Aluminum shock towers on that, leaving only plastic caps on the GTR shocks. Unless I upgrade to a set of Proline Power Strokes, then it will be all aluminum like the HR's.
  10. #50
    Jul 2013
    2,187
    Started assembly of the Rally to my specifications. I dyed the chassis black. I know I was waffling on this after dying Jordan's. I liked the look, but was not fond of the dye scraping off. I thought about it and afterward I decided, screw it, just do it as planned. I let it soak for 3 hours in the dye.
    After rinsing and drying it off, I set about assembling it with the parts I do have on hand. I installed an expanded battery strap to accommodate the bigger 4s Lipos I plan to run. This fit a 4500mah, 4s 70c very nice. Snug, but nice. It looks to fit a lot larger capacity, but I have a few brand new 4500s I'll use for now.
    I installed the new HR shocks and STRC caster blocks and steering blocks. This are nice units and fit with out issue. One item I was not too impressed with was the Golden Horizon's rear bearing carriers. I had to grind out with a dremel the inside bearing seat for the bearing to fit and sit in it properly flush. Not a big deal, but still.... I had read lots of good stuff on GHR stuff, but this was a slight disappointment. The only reason I went with GHR rears was they were out of stock on the STRC ones.
    My STRC 17mm hub adapters have not yet arrived, so I mounted up a set of 12mm wheels just to see how it would sit. The chassis is a but high right now with no weight in it, but it looks like it will settle in at or near where the Ultimate sits at its lowest setting. The HR shocks are stiffer than the Ultimate's GTR's from what I can feel. I like it!
    Still needing lots more parts but this is a start.
    Dyed LCG chassis
    Expanded battery strap in comparison to the standard one
    Disassembly of the original rear set-up
    Completed assembly of the new rear set-up
    Mounted in place
    Front section
    STRC servo arms are a thing of beauty
    As is this I think
    Another look at the back
  11. #51
    Jul 2013
    2,187
    With a body
    Beside the Ultimate
  12. #52
    May 2013
    Uk
    742
    Holy smoke.....that is looking absolutely divine.....your builds are amazing...and that rally is sooooo sweet with all the shiny stuff on it....I want one.......are you still going with the pug colour scheme?...
  13. #53
    Jul 2013
    2,187
    Thanks Simon! For the Focus, I'm not sure how it will be just yet. I have an idea but no Pug... If I got another clear Rally body I would do the Pug!
  14. #54
    May 2013
    Uk
    742
    Ford focus......hmmmmmm.......how about old school Colin McRae style...martini colours.??
  15. #55
    Jul 2013
    2,187
    I have to look into that! I was planing more of a street trim version sans decals but t may look too plain
  16. #56
    May 2013
    Uk
    742
    What are sans decals dude?
    Ken blocks fiesta ?...
    Ford toureno...starskie snd hutch style.....Lol
  17. #57
    Norfolk, va
    1,164
    He means no decals at all.
  18. #58
    May 2013
    Uk
    742
    Ahhhhh.....Lol....never heard that saying before....thanks
  19. #59
    20,522
    "Sans" is French for without. With = "avec."
    Alt-248 on the number pad =
  20. #60
    May 2013
    Uk
    742
    Merci...should of studied French at school...Lol
  21. #61
    20,522
    De rien.
    It is easier to marry someone who speaks it.
  22. #62
    Jul 2013
    2,187
    Thanks for the clarifications folks!
    Okay I keep dropping by the hobby store hoping they get more stock of paint for this project. But they don't. I the upside they did finally get the Tamiya Lime flake paint I had wanted for a different project . So I bought both cans. I wonder if I can work it into this paint job?
    Yeah part of me wanted to do this rally in street trim just so I could enjoy a single color body. However a full out replic race rally would be cool to model as well. Maybe something in between .....
    I picked up the E Revo clutch rebuild kit to convert this rig. As well I ordered the Hot Racing double pad clutch kit as well
  23. #63
    Canton Georgia
    2,149
    Still looks tres bon!! It is tres colore! Haha gotta love francais! Can't wait to see that focus body painted up! Gonna stick with the street fighters or are you going to switch them to 1/8th scale onroads?
  24. #64
    Jul 2013
    2,187
    Thanks, no I'm going to mount the Road Rage's/HBs once the 17mm adapter arrive.
    I hope to keep posting but I maybe banned out of here soon. I keep getting infractions for posting stuff that I'm not suppose to, due to my ignorance.... I guess until I know it all, I'll keep going until I'm punted.
    Received a few items to day.
    That Lime Flake paint I was talking about. Picked up a E-Revo clutch kit to upgrade the rally, and another extended battery strap for the Ultimate.
    Received the power system for the Rally today, as well as some dye able RPM rod ends.
    It's a Monster alright
  25. #65
    Canton Georgia
    2,149
    What color are you going going to dye the rod ends if you do dye them?
  26. #66
    May 2013
    Uk
    742
    [QUOTE=ViperZ;5568856]Thanks, no I'm going to mount the Road Rage's/HBs once the 17mm adapter arrive.
    I can't wait to see your bodyshell....are you gonna use the lime flake or lame flake....Lol...I have used that on a project once and it came out amazing...let me know what you think of the hot racing slipper as you know I'm loving the look of it....I really hope you don't get banned....that would be an absolute travesty....
  27. #67
    May 2013
    Uk
    742
    Also can you let me know if you have to grind part of the chassis out for that MONSTER thing your installing to fit
  28. #68
    Jul 2013
    2,187
    I dyed them red, but I'm not sure I like the look, so they might just be black...
    Thanks Simon! Not sure what I'm going to use the Lime Flake for. I wanted it for another Raptor Body I have, but we'll see.
    Thanks for those words, its has really put a damper on my enthusiasm here.....
    I fitted the motor last night with a 20/54 gear, no it seems to clear with out grinding. Not sure why that person had to do that in the other build
    I'll send those decals out to you today.
  29. #69
    May 2013
    Uk
    742
    I think I would like to do your focus doing a ford Focus ST scheme....main body lame flake and the stripe work with mirror chrome and some mirror chrome decals along the side skirts.....very basic but effective....sorry for keep making suggestion im sure yours will be far better.........can't help sticking my nose in.....yes that doesn't seem right as your threads are the most informative and interesting ive ever read!!!!
  30. #70
    Canton Georgia
    2,149
    I fitted the motor last night with a 20/54 gear, no it seems to clear with out grinding. Not sure why that person had to do that in the other build.
    Thats nice to know for when I get my et2400 in a month or so.....
  31. #71
    May 2013
    Uk
    742
    And thanks again for decals
  32. #72
    Jul 2013
    2,187
    I like the mirror chrome stripe idea, I was sort of wondering how it would look.. I Was thinking mainly white for the body, with red and gunmetal stripes... We'll see. I've started painting my Silverado for the Ultimate as a way of relaxation this long weekend.
    Thanks again for the kind words and support. This is the way things go, I'm not looking for sympathy, just wanting to keep you all updated incase you noticed a change in my tone and mood around here, or if you noticed I just stopped posting.
    Yeah it fit really nice actually. I'll post some pictures once I get them edited.
    No problem, I'm just paying it forward
  33. #73
    Jul 2013
    2,187
    Here are the dyed RPM arms. They color turned out okay for 1/2 hour soak. I installed one, not sure if I like it. It looks like "oh look at me" red plastic, where as the black just looks like stealthy black plastic. You can see the red con rod ends on the left rear camber link
    Here the test fit of the 1512 motor and Mamba Monster 2 ESC
    With Blower attached
  34. #74
    Jul 2013
    2,187
    Taking a break, while looking for inspiration for the Silverado body, I decided to go ahead and install the red connecting rod ends. I mean I may as well seeing as I went to the trouble of buying and dying them. I suppose they don't look so bad.
    I measured each one before disassembly so as to not entirely screw up set-up parameters. This way you assemble to the same dimension
    Back Section
    Front Section
    Overall
  35. #75
    Jul 2013
    Honey Brook, PA
    154
    looks amazing man
  36. #76
    May 2013
    Uk
    742
    Hi viperZ...chin up old boy and think of the ppl your entertaining.....Lol they kinda do but those rod ends look real good with your red carriers it suits the car well.....and Oooooooooooo that 1512... Im drooling....Lol....hey have a good relaxing weekend and paint or design them bodies with your heart and soul and know that the work you do is amazing and ppl love it.....
  37. #77
    Jul 2013
    2,187
    looks amazing man
    Thanks, not too shab for roller off ebay, hey?
    Thanks for those good words Simon! It was a beautiful day around her so I took the real car out for a drive, did a bit of shopping with the wife... Great day, still not ideas for the pint jobs,but it'll come to me
  38. #78
    Canton Georgia
    2,149
    How hard was it to get the ball joints in and out of the rod ends?
  39. #79
    Jul 2013
    2,187
    It was a snap using these ball end pliers. However you can just use a set of needle nose pliers as well, just bite on one side of the ball and the other side of the plastic con end, and you're good. Just be careful as many of the Traxxas balls have a larger flange on one side so you can only push it out one way.
  40. #80
    Canton Georgia
    2,149
    Okay thanks, looks like I may be dyeing some stuff when I get money....
