Results 1 to 15 of 15
    Alberta Canada
    1,011
    Revo 3.3 TQi Trottle and Shift channel not working
    Ok so i've never had this problem before its like the RX or TX is not working. The throttle and shift servos do not work, but if you plug them into the steering then the steering operates them no problem at all. Is there something to fix or will i need a new radio system.
    Australia, vic
    137
    Did you happen to put an iPhone on the dock before this happened?
    Sent from my GT-I9300T using Tapatalk 2
    Alberta Canada
    1,011
    Its not a telemetry truck. It is 2.4gz with opti drive.
    I un hooked the opti and used a different radio system to get the truck running
    Sent from my SGH-I317M using Tapatalk 2
    Jun 2011
    Copple Crown Mountain
    400
    Try it with the Stock radio now. Most take the opti-drive out because of the issues with it. If you don't go FOC, be careful, come to a complete stop before shifting.
    Alberta Canada
    1,011
    i tried with the opti drive removed, I guess with the Opti drive removed you need or should use the tekno RX box kit,
    Alberta Canada
    1,011
    Does the opti drive help with shifting? I thought it was only for reverse. I was going to remove the reverse but my revo came with telemetry already installed
    Posted by my Galaxy Note 2
    Jun 2011
    400
    The opti is a "fail safe" that wont allow the Revo to shift, forward & reverse, until it is stopped and idling. You can still get the FOC kit and remove opti-drive.
    somewere in ohio bashing a traxxas
    197
    what is the FOC kit?????????????
    Australia, vic
    137
    Forward only conversion
    197
    oh okay i gues that makes it faster??????????
    Jun 2011
    400
    Maybe a bit faster. Less weight.
    Sep 2013
    28
    I'm having the same problem..but I removed the opti and put my throttle servo directly into chan 2 to test it...No bueno. But my hitec server will work in steering channel.
    Sep 2013
    28
    Alright well I got my engine setup to replace the 3.3. The pipe came in yesterday and now only the receiver problems are holding me back...
    Sep 2013
    28
    Called Traxxas support because I attempted to reset my throttle servo settings etc via the radio controls and throttle still did not work. So I'm sending my radio sys and optidrive in for testing.
    Sep 2013
    75
    Hello Sgt., I like your set-up there I have two of those engines here that have been sitting a few years and need to be disassembled and cleaned and I was wondering if you knew of a supplier for parts such as wrist pins, and circlips for these guys?
