Results 1 to 2 of 2
Thread: crack in Hull
    Glendive, MT
    266
    crack in Hull
    So I have had this Nitro Vee sitting around for a while. Took it all apart to clean it and fix anything that needed to be fixed. Well, it got put on the back burner, and tonight while cleaning it up i noticed it has a crack in the hull. And I was wondering if there is any way to fix it or is it junk? I know parts are getting hard to find, at least for me, for this boat. But I really wanna get it together.
    Glendive, MT
    266
    Well..I think I have it fixed. Seems as how I work at a body shop, I grabbed some 3m Panel Bond adhesive. I was able to put pressure on the back side of the crack and was able to open it up just a little bit. When doing that I used a small brush to put some of the panel bond in the crack.
    I let it set up for a while, and started sanding on it tonight. Stuff is kinda a pain to sand, but the crack is sealed and when putting pressure on the back side to try and open it up, there is no movement. So we shall see.
