Results 1 to 9 of 9
    143
    suspension to make handel better
    got a revo about 2006. I mostly use in front of the house in the street and on grass. Since I have had it never really played with the shocks or suspension. My question is how can I make it A) Turn better meaning the turning radius and B) make it so that I don't flip over when making an abrupt turn?
    Aug 2013
    56
    http://traxxas.com/pitpass/howto/new...t-Guide-Part-2
    I believe a sway bar kit helps prevent it from flipping but I don't know what else will.
    Jun 2007
    Farmingville, NY
    682
    move the pushrods to the middle or outside setting on the lower a arms.. it will lower the truck and stiffen the suspension a bit..
    Traxxas please sell kits!
    Alberta Canada
    1,011
    Thicker shock oil will help a lot too
    The revo platform dont turn as sharp as the maxx platform. I have the wider steering bracket installed and I dont think it really did anything
    Posted by my Galaxy Note 2
    72
    sway bar makes huge difference.
    Arkansas
    527
    What Rocker's are you running? Which springs and shock oil are you running (front & rear)?
    I run P2 and/or P3 Rocker's with the pushrods in the center hole, 80wt oil (F&R) and Silver in the front and Blue springs in the back? As said above the sway bar kit makes a huge difference. I personnally like the Tekin sway bar kit and ONLY run it on the front.
    As for a tighter turing radius......you can change out the steering stop and gain a little.
    May 2007
    West Coast, Fl
    2,133
    The Blue and Silver springs are made for the LT Rockers. That is why they are shorter than the other springs.
    RBMods
    Arkansas
    527
    I agree, but they stiffen the suspension just enough for me on the 3.3; I adjust the preload if needed. I use same setup but have lightened the shock oil to 70wt and use green spings in the front and tan in the rear on my erbe. Sometimes Tan and Black but most always stiffer in the rear......I'm a basher.
    One thing I might add........I use the VDP kit on all my trucks. It makes a huge difference IMO. I use the #2 piston w/ the valve on top.
    Alberta Canada
    1,011
    I have the vdp in my erevo and one ordered for my 3.3, they make a huge difference. I also run the springs for the lt rockers on my p2 rockers.
    Posted by my Galaxy tab 3 8"
