    Sep 2013
    New Phaltlines Tremore fitting lose on my brand new E-maxx 3908 TRUCK
    I just purchased a set of hpi Tremore tire and rim pk once I snug the Rim/hex nut down & the wheel wobbles on the splined I also notice that the splined if smaller than the rim how do I fix this I know I'm not the only one with this problem, How do I fix it I really need all the feed back I can get at this point, if any of you guys have E-maxx with phaltline wheels if so how did you fix it JUST FOR THE RECORD All 4 FIT LOOSE once they were tighten if any of you guys have a set of phaltlines on your e-maxx please post them.
    please post you opinions don't just read and keep going guys thank you very much I am a newbie at this .
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
    Jun 2009
    Cocoa Florida
    Those wheels need a 17mm hex, sounds like your running the smaller 14mm hexs.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    muscoda, wi
    The traxxas 17mm tool for tightening wheels don't tighten all the way either for those hpi rims. I had to use needle nose pliers to slip in the nut grooves, and tighten rest of the way.
    May 2013
    I use a socket wrench to tighten my 17 mm wheel nuts. it might help you.
