I have an E-revo brushless and I have been constantly breaking my rear diff, what are the best ones out there that can take a beating? What diff isn't going to break on me?
there isn't one just yet, working on it.......
http://traxxas.com/forums/showthread...=1#post5575346
you can shim & buy an alum housing & alum carrier tho..
http://traxxas.com/forums/showthread...=1#post5342896
or do the LSTII mod...check craig.mitch316 thread..
Yeah the only solution currently is to do remove the stock traxxas diffs and replace them with LST diffs. However this require you to modify the bulkheads that the diffs sit in as well as creating some if the parts such as diff output shafts and centre drive shafts couplings. As 87 said - Mitch316's thread is the place to look for details in how to do this - I followed his guide and did the LST mod and haven't had a single diff issue since I did it!!![]()
How long do you think it will be before those new bulkheads are made? Will they be up for purchase?
Has that Hot Racing housing worked well for you? How long has it lasted? I run 6s and I don't know if I could live without it, so I need something unbreakable...
What's the link to Mitch316's thread?
the one that says MITCH316 ERBE rebuild
http://traxxas.com/forums/showthread...6-ERBE-rebuild
That we are not discussing. In that thread there is a moderator warning to stop asking that Question.
Nothing is full proof in this hobby sometimes we get buy with what we have. Sometimes anything is better.
Okay thanks 87 GN I appreciate it! Do you have a preferred website where you get these diffs?
Is it just me or do someone else find it strange that Traxxas do not want there users to get solutions to things like diff problems? I know LST diffs are from a diff brand, but Traxxas do not offer a solution so guess it would be better having customers using non Traxxas parts than having them change brand?
I get most of my parts off Ebay. I don't have a LHS any where close buy, (hour away) then they may not have what I need....
Wanted to share some general guidance on how I have kept the diffs alive in my trucks for some time.. Have multiple e-revos, my Summit runs 4S lipos geared for about 40mph, my 6S revo is geared for 60mph or so.. All have a lot of torque but I do dial down the amount of startup torque available using the Castle Link, run my slip with about 1/4 turn off and it has made a huge difference.
I have an extra set of the LST2 diffs modded but haven't put them in for a year since my 6S e-revo has held with stock, shimmed diffs. It's not the best example but I can still do a backflip if I like so it can jump if it needs to..
Thanks padrino, what size shims do you use?
Are these the right diffs to buy?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=350896442474
and
http://www.ebay.com/itm/Alum-Diff-Ca...item3cd540800d
I'm not sure those diffs use the heavy duty diff cup. Looks like the place where I bought them from are out, but you need the one with the round diff cups, the heavy duty ones.
I guess I'll have to wait until they get back in stock then!
Yep you have a seller on Ebay, Jenni RC sports if I recall correctly, that parts out vehicles, including the Losi LST. Those are the differentials you want.
is this the same thing? http://www.amainhobbies.com/product_...sembled-LSTAFT
Nope, looks like the normal version. This is what you need for the heavy duty version:
http://www.amainhobbies.com/product_...ferential-Case
That's only the case though?
I know this is 4 years old but did they ever make a heavy duty diff? I'm looking to upgrade mine but can't really seem to find anything unless you want to do the mod.
I did the losi mod recently and now I actually use the truck again. Hot racing came out with a diff housing that uses a bigger pinion bearing. For me the pinion bearings failed almost every time killing the rear diff. Might be worth trying the new housing first
Leading Edge Machining has a very good quality upgrade for E-Revo diffs, and you won't have to do no b.s. Losi mod.
https://store.leadingedgemachining.n...e/default.aspx
For some reason the link doesn't let me go right to it please advise me where to go for the differential you speak of
Fueler941 ?????????
They are back to selling on Ebay. Check out this thread: forums.traxxas.com-Lem
