Results 1 to 11 of 11
    Nov 2013
    Missouri
    229
    New e-revo owner
    I got a e-revo brushless about two weeks ago and am running 4s lipo I ran it and did break drive shafts but a lot said that will happen pretty quick we'll after fixing that with the upgraded ones from traxxas I took it out this evening and was running it and I haven't did any jumps just few runs up and down the street and few wheelies but notice my driver side front tire isn't spinning when I hit the throttles do when I pick it up I can free spin it kind of like it's not connected but drive shaft is connected so i don't know if it's a diff problem so any help please
    Jul 2012
    Yakima, Washington
    1,440
    Maybe you stripped out a wheel hex?
    RC Champion NFS's Avatar
    Aug 2013
    2,097
    Front center driveshaft might be stripped/broken.
    Nov 2013
    Missouri
    229
    Wheel hex is fine might have to check drive shaft connecting to diff but looked fine thanks guys
    Oct 2013
    431
    Check the grub screw that holds the stock drive shaft to the diff or if you went with the CVDS then the grub screw that holds the drive cup to the diff.
    kansas
    8,677
    I am think'n a stripped diff.......
    if all the drive shafts are good..
    Nov 2013
    Missouri
    229
    We'll the back two wheels work and front passenger side works bout half speed, since this my first e revo what can I do about not breaking diffs I read up some on this issue haven't really found a answer any help and anything else that's important to know bout this car and what I show watch this car main just going to be racing up and down the street maybe some off road but not much so any help on how to set up or upgrade I should do I do run off upgrade as they break policy
    Slash 4x4 & E-revo brushless
    kansas
    8,677
    shim as you prob already know, or the LST mod.........
    Nov 2013
    Missouri
    229
    What's lst mod?
    Sep 2013
    245
    Quote Originally Posted by Alan_hornet View Post
    What's lst mod?
    Putting in the losi lst2 diffs rather than the e revo diffs. Does require a dremel or a heat gun. Been doing a lot of research as that's my next mod when I break a diff. 2 months on 6s and haven't broken one yet.
    Sent from my SM-N900P using Tapatalk
    kansas
    8,677
    one of many in the Forums Craig has a mod in his build thread, along with others
    http://traxxas.com/forums/showthread...-LST2-diff-mod
