Results 1 to 14 of 14
    Oct 2013
    88
    Weirdest problem
    My sisters brushed slash 2wd was running fine until recently. We were driving it on some ice and then it just stopped. The xl-5 and receiver looked fine, all lights working. Steering didn't work or throttle. I bring it home and open up the receiver box and take out the steering servo to see if the servo was bad. Nope. After a bit more fiddling around, i test the the throttle. Nothing. The steering left. Turns. Steer it right turns, but, also activates the throttle weirdly.
    Over all, when you steer it right, it steers and goes forward. No reverse. No brakes
    Nov 2011
    North Central OH
    1,050
    Did you flip a switch on your controller, go into 70/30 mode or anything?
    Oct 2013
    88
    Nope. Same as usual. I did try all the reciever connectors
    Netherlands
    97
    Looks like your Esc is the problem. Maybe start all over again with coupling receiver with the transmitter and calibrate. Futher no idea's
    Slash 2WD lcg Chuckworks & 2WD lcg Traxxas
    Summit
    Mar 2013
    New Hampshire
    755
    Its either the esc going wack or you flipped a switch on the radio. Take your transmitter out and look at the switches to the right of the ON switch and make sure both of those are put to the left. If your remote is 2.4 GHz look in your manual because I'm outdated and I have three 27 MHz radios
    And we thought toy grade RC's where cool...
    Brooklyn Park, MN
    1,249
    Sounds to me like you have your ESC and servo both on ch1.. Probably not but that's what it sounds like, ESC should be channel 2.
    Sprint S4 | Tapatalk 2
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    Michigan
    8,203
    Quote Originally Posted by Kitteh298 View Post
    Thats what it sounds like to me as well, if you pulled any of the plugs out of the receiver you might wish to double check.
    If you did your not alone, I think we've all done it once, I've done it several times, its not hrd as there are two channel ones.
    Oct 2013
    88
    So I think the esc is screwed over. I did mess up on the receiver but put it right. The steering is the only thing that works as of right now. Is there a way to test the esc?
    Thnx
    Mar 2013
    New Hampshire
    755
    I've seen the problem where the truck only steers and I've taken there truck and just blown out different connections and it would start working. The problem is I don't know what connection solved the problem. Before trashing the esc do what I did so you don't waste money if you don't have to.
    Michigan
    8,203
    If the esc engaged the motor when plugged in incorrectly it sounds like the esc is functioning correctly.
    It sounds a bit more like the receiver is the culprit.
    Your saying when the esc is plugged into the channel 1 slot it turns the motor with the steering wheel?
    Oct 2013
    88
    Ya. Something like that
    Michigan
    8,203
    Quote Originally Posted by bdog325 View Post
    Imo the receiver is the culprit here, the esc is getting the same single from the receiver on channel one as it would on c#2.
    Plug the servo in to the #2 slot and see if it works with the trigger, if not sure sounds like the receiver to me.
    Mar 2013
    New Hampshire
    755
    The receiver shouldn't be the problem unless he was playing around with it or one of the plugs came loose. Its the transmitter, make sure every thing is on the right channel.
    Michigan
    8,203
    Quote Originally Posted by CBD55 View Post
    Could be the transmitter but he said he plugged the receiver in wrong in a previous post.
    Either way it doesn't sound like the esc.
    I've never been one to say something is or isn't the issue, just voice opinions.
    I've worked on 1:1 cars for 34 years but these new rc's are still unprecedented and at times evanescent to me.
    Just thought plugging the servo into channel 2 would pin point the issue.
