What is the max input voltage to this RX?
Traxxas TQi 5-Channel Receiver
Land, Sea & Air, A true RC Addict
I was hoping someone would chime in... lol
I don't know for sure, but I doubt it is much over 6 volts. Maybe a call into Traxxas support is in order??
I guess Ill have to. I wanted to bump up the voltage from 5.5v to 6.6v if it was okay. Because I a futaba servo thats 6.6 to 7.4v I plan to use.
They said 6.0v is about as max as you would want to go. They said anything above that and it will work for a while then fry.
Do you use telemetry?
Yes
Mobile
http://www.hobbypartz.com/79p-it4-to...io-orange.html
8.4v receivers...
That looks interesting. Thanks
Mobile
I didn't read the full spec, but I don't think it supports CLL(Castle Link Live). Which is where the TQi gets it's data. All the modules look like a pain to rig up.
You could just run the Futaba servo on a stand alone BEC.
I burnt mine! As soon as I plugged in my mamba x set at 8volt into this trx1090 smoke came out and went it goes!I wouldn't power more than 6 volt as said above and if u need more power I would suggest bypassing n power direct to servo from such as Castle bec! Which I hav rigged most my rigs.
Sent from my SM-N950F using Tapatalk
